04-14-2009, 09:10 PM | #1 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| Failed Mini Skeeter Build/t
Found a mini skeeter in the mailbox $30 later...Finish is prefect and everything fit together without having to modify anything. mini sidewinder, cc bec, hs645mg servo, HH torquemaster mini. Running blue claws on axial beadlocks with 3oz in each wheel up front and .5oz in the rears, cvds up front and stock axles in the rear for now. 8.25" wb and 1.75" belly height. receiver mount Using associated 18r body posts, had to dremel a notch on the tvps. Servo setup using the fubar 4 link mount included with the kit, shaved the axle mounts/stubs front and rear and had to get rid of the ota steering:-( knuckles shaved to get as much turning radius out of the cvds with the stock plastic ones. Shaved as much weight as I could off the tranny and only other thing on the chassis is the bec and wires. bottom... Begining of my practice course guesstimate of 4tons so far...see if you can spot the crawler... Only torque twist is in the driver rear when going in reverse otherwise there is none when going forward. Links are 4-40 allthread with linkage slider tubes on the outside, will make up some derlin links later. Comments/criticizm welcome |
04-14-2009, 09:27 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
did you get that skid plate with the chassie nice build i need a skid like that |
04-14-2009, 09:27 PM | #3 |
Pebble Pounder Join Date: Mar 2009 Location: gilbert
nice! are you going to have it at the comp this sunday? we'll have the first mini skeeter out there this comp.
04-14-2009, 09:33 PM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: Phoenix
Damn, gonna be too many mini-skeeters out there Sunday! Things are sprouting up like weeds. It's an awesome chassis, looks like you have some good tricks on yours. Where you getting your rocks & boulders? I've been hauling in rocks from the desert, but that's getting old... Like to have some decent sized boulders delivered. Rich C. |
04-14-2009, 09:47 PM | #5 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Nice back yard. I can remember when mine in Mesa looked like that. Rig looks good |
04-14-2009, 10:11 PM | #6 | |||
have another 150 feet on that wall to run more rock...Have 1/3 acre in the backyard to landscape still | |||
04-14-2009, 10:12 PM | #7 |
DOOH!!! Join Date: Feb 2007 Location: AZ
Looking good!! Not sure about the title of the thread though.. How are the 4-link plates working out? |
04-14-2009, 10:20 PM | #8 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
04-14-2009, 10:21 PM | #9 |
04-14-2009, 10:33 PM | #10 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Damn i didnt get a 4 link mount with mine. Nice build man.
04-14-2009, 11:26 PM | #11 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
Me Either, whats up with that John???????, and after I sent you all that new stuff. Failed, nice looking skeeter, I need to get mine out sometime. |
04-15-2009, 12:50 AM | #12 |
I just got mine last tues so maybe its a new part of the kit I was going to use my lexan 4 link plates but these were thinner and used them to get the servo lower.
04-15-2009, 04:26 AM | #13 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
I checked the sticky but no link to the sceeter chassis. where can I check it out?
04-15-2009, 09:13 AM | #14 |
04-15-2009, 09:48 AM | #15 |
04-16-2009, 09:20 AM | #16 | |||
Thank you Sir, you bringing it out Sunday right? | |||
04-16-2009, 11:27 AM | #17 |
Yup, should have a new body from tcs today just not sure if I want to paint it or leave it clear...
04-16-2009, 05:06 PM | #18 |
I will have mine out too and a new suprise body. |
04-18-2009, 02:12 PM | #19 |
First time painting a body...outside looks great, inside looks like I painted it by hand when I tried the bag trick to marbleize the paint...went all green after that... |
04-20-2009, 02:32 AM | #20 |
Pretty sure mine wasn't the only mini skeeter that finished in the top 5 today, in a 1.9 class with 25 people Last edited by Failedabortion; 04-20-2009 at 02:36 AM. |
