| | #1 |
| Pebble Pounder Join Date: Apr 2009 Location: West Monroe
| On my MRC when the back wheels get a bind on them they quit pulling but the drive shaft is turning i just took the whole axle apart and didnt see any stripped gears or broken parts. any ideas? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| Sounds obvious but I have over looked this before as well, check your set screw on your driveline going into the rear end. Or it might be your lockers. If your still running plastic they can be stripped and actually not look like their in bad condition. |
| | #3 |
| Rock Crawler Join Date: Mar 2009 Location: Cottontown
| First, I would recommend that you replace both front and rear lockers with metal units from RcBros or Losi. They almost always cure the problem. I know when mine went out, everything looked fine in the tranny, no broken gears no broken axles, nothing. Then I unscrewed the diff screws and looked at my lockers, couldnt tell right away that anything was wrong. So I pulled the lockers out. Sure they look fine from the outside but upon closer inspection the rectangle hole in the center of the diff had rounded out. Since it only rounded out on the right side of the diff then It still worked like I had 4wd on flat even ground and even slight inclines, but I could hold the right side rear tire and apply power and it wouldnt do anything. Diff lockers. But as drvn said, it cant hurt to check those set screw. Even if you find out that the screws were loose I'd still throw in some metal lockers. |
| | #4 |
| I have seen the metal lockers and got them on the way however some say you have to have a center locker? does this make any sense? |
| | #5 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| You can replace the center locker if you feel like you need to. I beat on mine with a trinity wild monster and a HH torquemaster mini without breakage. |
| | #6 |
| you dont have to, and they almost never go bad, but I went ahead and replaced mine when I did the front and rear. I figured I already had it apart I might as well. Its good insurance too. But no, you dont have to |
| | #7 |
| Quarry Creeper Join Date: May 2006 Location: Snake Run, IN
| | #8 |
| LOL, abusive bastard. I got a spare set of plastic ones layin around if you need em' that'll be 22.00 each half. So how does 44 bucks even sound, I'll even ship em for free |
| | #9 |
| Am I mistaking or are you trying to sell me plastic replacements for 44 bucks?? |
| Thread Tools | |
| Display Modes | |
