Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: im getting tired of this
Old 05-09-2009, 08:40 PM   #1
Default im getting tired of this
the slipping nosie the axle makes some times well mines doing it and im ticked so i replaced both the ring and pinon(only the ring and pinon not and of the plastics) hoping it would solve it becaus i just got my flat irons but it still does it and im really pissed off so can some one help me out here(i can here it coming from the rear axle)
rccrawlerguy is offline   Reply With Quote
Old 05-09-2009, 09:19 PM   #2
Building Not Buying
CD13's Avatar
Did you look at the locker?
CD13 is online now   Reply With Quote
Old 05-09-2009, 10:06 PM   #3
yes when i replaced the ring and pinon and there losi metal ones so i would think that there fine and i didnt notice anu damage
Old 05-09-2009, 10:14 PM   #4
see if there is to much side to side play in the axle housing...Had to shim my diff even in a brand new housing.
Failedabortion is offline   Reply With Quote
Old 05-09-2009, 10:21 PM   #5
TEAM MODERATOR
Reflection's Avatar
Whats wrong with that?
Every shaftie I've owned has been shimmed up new or used. Proper/good gear mesh will be stronger and your gears will last longer.
Reflection is online now   Reply With Quote
Old 05-09-2009, 10:41 PM   #6
Ya I just stole some shims from an 18t diff
Old 05-09-2009, 11:30 PM   #7
please give pics of the shims thanks, im going to try the washer method i just need to find a washer... too bad the lhs is not open at 10:30
Old 05-09-2009, 11:36 PM   #8
http://www3.towerhobbies.com/cgi-bin...?&I=LXJZH4&P=Z
Old 05-10-2009, 01:48 AM   #9
Check out my thread "fed up" its about a week old, goes over all these issues!
Drvnbeing is offline   Reply With Quote
Old 05-10-2009, 12:01 PM   #10
So you never were able to pin point the problem? I too have the clicking under load.
LuvMyTJ is offline   Reply With Quote
Old 05-10-2009, 04:43 PM   #11
i have not found out the problem, ill have to get some diif shimms but for now i kinda shomeed it a dumb way, but she still clicks
Old 05-10-2009, 08:21 PM   #12
ok so i fixed it(at least i think so) i pulled out the pice that pilgs in to the axle and out the out side of the axle where it goes in is a very thin washer so i put it on the inside of the axle and i went and dug thru the washer bucket and found a washer that is preety this but it would fit over my berring in the diff so i put it in the vice and ground some down till it would fit and put it all back together and bam no clicking with the 90* wall test now for the rocks
Old 05-10-2009, 08:45 PM   #13
Not trying to thread jack but heres the link to a thread thats this has been talked about. Fed up!
And yes the clicking has stopped, not sure what exactly it was but I think one main cause of it was too much weight being ran up front.
