Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Motor
Old 05-10-2009, 02:46 PM   #1
Location: Work on large yachts so mostly in the Mediterranean
Default Motor
Hi burnt out my SCU and my be looking at Brush-less. Will the LOSB9562
1/18 Xcelorin 8200Kv Brushless Combo work. The SCU is programmable and has brake but not shore if it has drag.
busterb5 is offline   Reply With Quote
Old 05-10-2009, 02:59 PM   #2
yes it will but that is way to fast if you went bl then i would get the novak mini mongoose and if you already have and esc then get just the mini mongose moter
rccrawlerguy is offline   Reply With Quote
Old 05-10-2009, 03:12 PM   #3
What Kv is ok for mini crawler
Old 05-10-2009, 10:17 PM   #4
Novak only offers the one mini crawler motor
nightcrawler86 is offline   Reply With Quote
Old 05-10-2009, 10:46 PM   #5
you have to get sensored so you can actually do low speed.
crawladan is offline   Reply With Quote
Old 05-11-2009, 06:36 PM   #6
fordwheeler's Avatar
the novak mongoose crawler mtr is 4400kv & is only available in a system (mtr-esc-15tooth pinion) awesome wheel speed/torque
fordwheeler is offline   Reply With Quote
