| | #1 |
| Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
| Alright so I am wondering what shocks you guys are running, spacers weight etc. and what hole locations you are attaching them too. Just curious to see everyone else's set up and see if I can improve on my own at all. Right now I am running my shocks on the very last (closest to the motor) hole on the top front and rear. Running inner and outer springs on the losi aluminum shocks with 80 in the rear and 75 in the front. I just changed to this the other night and it has improved alot from where I was. Ay input would be appriciated. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2008 Location: Ukiah
| im running my shocks with the stock spacers 4 on each shock and im running them in the first row 4th back i think i like em there it rides nice and low i have 70w shock oil and have stocd springs on aftermarket threaded shocks |
| | #3 |
| Rock Stacker Join Date: Oct 2008 Location: gainsville
| My brother runs on he was running losi shocks with the blue springs .We were having problems with it unloading on climbs. He is now running a droop set up and it works great. |
| | #4 |
| Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
| Losi Shocks front: top row, all the way back, inboard mount 1/2 inch spacing, 1000wt diff oil, 2 hole piston, 3 spacers, blue springs Rear: top row, 1 hole out, 1000wt diff oil, 2 hole piston, 4 spacers, blue springs |
| | #5 |
| Quarry Creeper Join Date: Mar 2009 Location: ON THE ROCKS
| my freinds running right about what chetly is running and he loves it |
| | #6 | |
It would be nice to get Ted, Chino, Bcrofts, and/or Nluv in here to see if any of us are close to what they run Last edited by chetly; 05-13-2009 at 11:17 AM. | |
| | #7 |
| New Papa! ![]() Join Date: Dec 2008 Location: With the ATL Crawlers
| Shocks - Losi aluminum - limited using stock limiter + (4) 1mm spacers Springs Front - Mini T soft - silver color Springs Rear - Stock Losi Aluminum - dark blue color Shock Oil - 40wt all four corners Front Location - 2nd row from top - third hole back - outboard Rear Location - 1st row - third hole - outboard Setup works great, 2 inch GC w/ claws, 65 degrees Last edited by Sneed; 05-13-2009 at 03:57 PM. |
| | #8 |
| MadDogRC LLC ![]() Join Date: Mar 2007 Location: Petaluma
| Losi aluminum shocks, blue springs, 4 spacers under piston, inboard kit and 1000wt oil up front, 45wt and stock location for rear...works like a champ Mad's DarkSoul Chino 1.9 |
| | #9 |
| Pebble Pounder ![]() Join Date: Dec 2008 Location: San Jose
| Boy, sorry for not getting in here earlier, just been swamped lately. Anyways, I use the Losi aluminum shocks, springs that came with them, just enough preload on the collars to keep the springs from popping off the perch. 70wt in the rear, and 80wt in the front which uses the inboard shock mount. I think it does great, but you need to slow up a bit when transitioning over extreme edges and whatnot, give the suspension a few seconds to do it's thing. |
| | #10 |
| So what's the word on the 2.2 chassis, Darksoul |
| | #11 | |
| | #12 |
| thats not chino thats ted. chino is chino63 and he hasnt chimed in yet. if i rememer correctly he is in recommended hole in rear and 1 hole back from that in the front. |
| Thread Tools | |
| Display Modes | |
