Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: my hunk of junk
Old 05-13-2009, 11:33 PM   #1
Default my hunk of junk
mods,
-PVC beadlocks tanks to Miller's build thread
-CKRC wiggle servo...stock one is junk.
-home made servo mount
-custom brass wheel weights, not sure on how much they weigh
-losi body, MLST/2
more to come as time and Money permit.... mostly money....
drift_this is offline   Reply With Quote
Old 05-14-2009, 06:45 AM   #2
Originally Posted by drift_this View Post
mods,
-losi body, MLST/2
Limit your shocks internally so this doesnt happen ^^^^^
It helps a ton.
soundcolor is offline   Reply With Quote
Old 05-14-2009, 04:01 PM   #3
So what doesn't happen? Unless you are talking about the spring hitting the servo?
imboostedru is offline   Reply With Quote
Old 05-14-2009, 04:43 PM   #4
more info on your wheel weights?
rex cars is offline   Reply With Quote
Old 05-14-2009, 05:28 PM   #5
See how your shocks are unloading in that pic.
You most likely have a couple of spacers on there.
If you remove your spacers, and internally limit your shocks, you will lower your ride height and also control shock and spring movement alot better.
Old 05-14-2009, 05:37 PM   #6
So its bad for the springs to unload? 1:1 rigs unload springs all the time. I aalso want more info on the wheel wieghts. I havent ran my MRC yet cause i got one that had a bad ESC out of the box %#@%! but i would think the more flex you have the better it would climb to a point. I understand the weight exchange is a big deal cause if you flex great but it takes to much weight off one tire or two then you arent going good. Just trying to clear things up for myself.
Cole
JOMJ87 is offline   Reply With Quote
Old 05-14-2009, 06:32 PM   #7
Ditto
BJoe is online now   Reply With Quote
Old 05-14-2009, 09:32 PM   #8
I had a turbo shop mill them out of a solid chunk of brass. Take all the space of the inner wheel, minus the steering knuckles in front and fill that with the material, pics below. I can have more made for anyone interested. there will be a cost for sure, but if I can get enough to buy maybe it will be cheaper. the "beadlock" keeps the weight secure into the tire.
Old 05-14-2009, 09:42 PM   #9
Cole
Its not bad to unload the springs, its bad to have them unload to the point of making the chassis unstable.
Old 05-15-2009, 09:19 AM   #10
fordwheeler's Avatar
good idea on the wheel weights looks clean, alot better than a bunch of lead packed in there!
fordwheeler is offline   Reply With Quote
Old 06-27-2009, 09:45 PM   #11
Are you able to make 8mm(bore)X15mm(diameter)X5mm (width) brass bushings?
Ripperfi is offline   Reply With Quote
Old 06-30-2009, 12:04 AM   #12
I like to #*&^
yup looks prety janky.
2500hdon37s is offline   Reply With Quote
