Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: TorqueMaster Mini reversed? swap wires it that OK?
Old 05-14-2009, 11:37 PM   #1
Default TorqueMaster Mini reversed? swap wires it that OK?
I just installed my TorqueMaster Mini and when I press forward on the controller it goes backward and visa versa. how do I fix this? just put the red to the black and black to the red wires? or is it something I did wrong when installing it?
thanks,
Jonathan
lostissues is offline   Reply With Quote
Old 05-14-2009, 11:39 PM   #2
you can either switch the wires, or you can flip the switch on the top of your radio...
Either way is fine.
soundcolor is offline   Reply With Quote
Old 05-15-2009, 12:09 AM   #3
thank you for the quick reply it flipped the switch and it works great.
I guess I didn't think it would be such an easy fix, I never thought it would be built into the radio.
Thanks again.
Old 05-15-2009, 06:52 AM   #4
anytime
Old 05-15-2009, 06:54 AM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I set the motors at zero timing, so swapping the wires is OK too. Swapping the radio does work just fine.
JohnRobHolmes is offline   Reply With Quote
