Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: 1/18 scale, why doesn't my MRC weigh over 100lbs?
Old 05-15-2009, 01:36 PM   #1
Default 1/18 scale, why doesn't my MRC weigh over 100lbs?
What, a full size rig weights in at over 3000 lbs huh? just a guess, so what's up with the scale on weight?
It certainly climbs better with another 1/2 lb added to it but I'm not sure where I'd fit another 100.
punk is offline   Reply With Quote
Old 05-15-2009, 02:52 PM   #2
Karadjas's Avatar
1/18 the length, 1/18 the width, 1/18 the thickness.
so 1/5832 the mass.
Plus, the designs are completely different and with different aims, so the weight will never match.
Karadjas is offline   Reply With Quote
Old 05-15-2009, 03:04 PM   #3
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Yup...different math. The "scale" that you see on RC's only apply to it's size. Not to mention...there's the whole factor of the materials used to build the 1:18 are lighter than all the steel parts of a full size.
Offroader5 is offline   Reply With Quote
Old 05-15-2009, 05:05 PM   #4
so 1/5832 the mass.
So if I have a cube of steel, and another cube of steel that is 1/18th the size. The smaller one will weigh 1/5832 as much? I question the math.
It's more like: If you made a full size crawler out of hollow plastic, and a few aluminum pieces, the scale weights might be closer. If you look at CCFBERG's scale tuber build, it ended up being really heavy.
cruzer971 is offline   Reply With Quote
Old 05-15-2009, 05:52 PM   #5
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Scale is CUBIC is what he is getting out.
Harley is online now   Reply With Quote
Old 05-15-2009, 05:58 PM   #6
I like to #*&^
yeah your wayy off with weight because of the materials and a cube of steel and the 1/18 version of it would weigh an 1/18th of the size because its the same material
2500hdon37s is offline   Reply With Quote
Old 05-15-2009, 06:12 PM   #7
Throwing Grenades
Harley's Avatar
No!
It is not because of the material alone. If you had a 1/18th SCALE version of a block of steel it would be 1/18 the lenght so it would take a row of 18 to make it as long.
Then you would need 18 to make it as wide.
Then you would need 18 stacks of those high!
Therefore....18 long x 18 wide=324 then 324*18 tall = 5832 blocks of steel
If you had a block of steel that was 1/18th weight it would not be the same size. Get it?
Old 05-15-2009, 06:26 PM   #8
DBR
Way too much math getting thrown around for something that I am pretty sure was meant to be funny by the OP.
DBR is offline   Reply With Quote
Old 05-15-2009, 06:46 PM   #9
Originally Posted by Harley0706 View Post
No!
I got ya. It's not really all that complicated.
amorton94 is offline   Reply With Quote
Old 05-15-2009, 10:40 PM   #10
something else funny, have you compared your 1/18 mrc to your 1/18 mini-t,yeaaaaahhhhhhh. sometin seems a bit off thereb
screaminsavage is offline   Reply With Quote
Old 05-15-2009, 10:57 PM   #11
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
easier math:
1x1x1" cube of aluminum = 1" cubed volume
10x10x10" cube = 1000" cubed volume that weighs 1000x as much.
The rig is shrunk in three dimensions.
JohnRobHolmes is offline   Reply With Quote
Old 05-15-2009, 11:46 PM   #12
Now I understand how that makes sense. Thanks for clearing that up.
