12-27-2009, 02:32 PM | #61 |
Ok, I measured the turning radius of 21.5" from inside wheel to inside wheel.
12-27-2009, 05:43 PM | #62 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Mine is at like 4 feet! And that was a big improvement over stock. Looks like i need to do some grinding to my dogbones. Thanks for checking that for me. The club in town is having its first ever 1.9 comp i two weeks and Parker is our course designer so i need a rig that can turn. | |
12-27-2009, 07:02 PM | #63 |
That is with the Losi CVDs...
12-28-2009, 11:59 AM | #64 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
How are those CVD's liking that steering angle ? The setup looks killer How long did you have to wait on the knuckles ? |
12-28-2009, 12:46 PM | #65 |
The CVDs seem to be holding up fine....we'll see when I get more drive time on the truck. The knuckles came in fairly quickly! I'd say about a week... |
12-30-2009, 06:41 PM | #66 |
I got some new tires in this evening: I'll give 'em a workout tomorrow morning. |
01-01-2010, 08:07 AM | #67 |
01-02-2010, 02:16 PM | #68 |
A slight update to the steering setup: |
01-11-2010, 11:02 AM | #69 |
21.5'' that's insane. I came out at 27''. Quick ?. How you starting ? Starting w/ rear or front tires. Meaning, I used a measuring tape, started at the end of the tape w/ rear tires centered w/ tape measure. Full locked one direction, kinda at a slow crawl. Ended around 27'' ish w/ front tire. This your way? This was on carpet as well.
01-11-2010, 11:28 AM | #70 |
Jeremy, how much the knuckles set you back ?
01-11-2010, 11:41 AM | #71 |
| They werent too bad: http://www.rccrawler.com/forum/showthread.php?t=209205 I went in on an order with some other local guys, so we combined shipping and saved a bit. |
01-11-2010, 11:42 AM | #72 |
how bout the tires? significant improvement over the others youve tried? and what others have you tried? |
01-11-2010, 11:53 AM | #73 |
Oh....most definitely! These tires and foams are the best I have run. So far I have tried the Blue Claws with blue foams, Chisels w/Proline memory foam, and the red dot Cobras with blue foam. Before I got the Rovers, I had good luck with the Cobras, but I think I'll stick with these Rovers.
01-11-2010, 12:05 PM | #74 |
RCC Addict Join Date: Apr 2009 Location: Anderson
I have got some "goodies" heading out today for you. This should really help you out at the next comp! -Jason |
01-11-2010, 12:07 PM | #75 |
Awesome! I cant wait! |
01-11-2010, 12:18 PM | #76 |
01-11-2010, 12:26 PM | #77 |
01-11-2010, 12:36 PM | #78 |
01-11-2010, 12:37 PM | #79 |
Yep, last...81st, 28th, then 1st!
01-11-2010, 12:43 PM | #80 |
1st in my back yard!!!!!!!!!!!!!! I dont know what it was at states there wasnt that many drivers in either class at disney. 80/27 |
