11-06-2009, 06:06 AM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: here
| my 1.9 Sling Shot comp rig
Alright guys I decided to run 1.9 this year. Wasn't happy with my frist chassis setup. So spent some more $$. The Mini Quake shocks seem to work really smooth. I have like 2 3/4" of articulation. Here's what I have so far. SS chassis Duratraxs Mini Quake shocks moped esc stock motor Airtronics 94357 servo cut and shut M3 Moabs stock wheels stock body comming soon: rcbros diff lockers and losi center diff gona try a Integy V10 25x1 motor do you guys think this motor will work 10t pinion? |
11-06-2009, 11:48 AM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
Diggin' the tires. Looks like they would sidehill well with the right foam set-up, how is the foward bite?
11-06-2009, 12:57 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Looks good How's that moped esc? oh and anything is a improvement over the stock can....except for the fireball I think their brushes are made out of cheap flint |
11-06-2009, 04:38 PM | #4 |
| Thanks... the tires seem to work. I first had some stock proline mem foam in the front and the tire would roll over on sidehill. With frim foam in the front seems to work alot better need to run it more and see. |
11-07-2009, 02:32 PM | #5 |
Newbie Join Date: Jul 2009 Location: north idaho
setup looks good
11-12-2009, 06:46 PM | #6 |
Newbie Join Date: Oct 2009 Location: Naples
| Nice 4 link set up workin on one for mine. Looks good... -CLIFF- |
11-14-2009, 08:07 PM | #7 |
Update..... Installed RCBROS F/R diffs. quick and easy to install. Also Losi steel locker for the trans. Changed the stock motor out to V10 25x1 motor 10t pinion. I'm only running a 5cell nimh 1500mah split pack as of now with the faster motor really don't miss that 6th cell. It also helped to keep the motor cooler. my motor temp w/7 cells was hitting 156 very hot after about 10 to 15 min of run time. I love this 1.9 comp rig it's a blast. Only if I could pick the right lines. |
12-14-2009, 11:04 PM | #8 |
| update steering
Used ax10 link/rodends as you can see bent & cut the link was able to use the link for both parts for the steering. was an easy mod works great. also running 25 mamba esc and lipo all this made a hell of diff. rig ready to go just need to learn how to drive. the chessiels are defently worth the money. Next I need to get a new body Last edited by tapped-out; 12-14-2009 at 11:14 PM. Reason: more info |
12-16-2009, 07:03 PM | #9 |
Rock Stacker Join Date: Dec 2009 Location: salt lake
nice car really like the sling shot chassia |
12-17-2009, 06:15 AM | #10 |
08-03-2011, 11:05 AM | #11 | |
Quarry Creeper Join Date: Jul 2011 Location: Hemet
08-03-2011, 01:04 PM | #12 |
