11-13-2009, 11:26 AM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Bismarck
| MRC mixer adjusting?s
Ok i just got done building my mixer. My questions are what adjustments are going to help get rid of my torque twist? I have it setup with upper links in rear second hole up third hole toward the center of chassis. And the rear part of the link is mounted in the rear holes. The shocks are mounted top hole all the way to the end of the chassis. The lower links are mounted all the to the outside of the chassis. same setup in the front also. My other question is i can't get my servo to turn the tires all the way both ways i got it close but i notice it turns to the right quit a bit sharper. The servo horn is about vertical and is toward the left side of the chassis with the stock link.
11-13-2009, 07:14 PM | #2 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
remember just cause it looks straight, it may not be straight. throttle and adjust. | |
11-13-2009, 09:46 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Pics
04-10-2010, 06:11 PM | #4 |
Newbie Join Date: Mar 2009 Location: ft.benning
i had the same problem with the steering try flipping the servo over so the top becomes the bottom if you are using the stock steering thats what i did and got all my steering back...
04-10-2010, 06:17 PM | #5 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Pictures of your current setup will help us better determine where your torque twist is coming from. The last post I saw regarding out chassis and torque twist the user had his nimh battery zip tired to the side of it. Which a quick pic we instantly knew the issue. |
