01-12-2010, 12:39 PM | #1 |
Newbie Join Date: Apr 2009 Location: Auburn
| Mini torquemaster ????
Installed and I have a stall prob.... reciever and esc keep power led's on when stall occurrs, if I rotate the tires a little it works for a bit then same occurs, and no the pinion mesh is not too tight. what now? Brent |
01-12-2010, 01:32 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: vacaville
try running it non-stop for 15 mins going forword at full power. This is to set the brushes to the com (sort of a break-in for the motor) do not reverse If this dose not work maybe someone else can help. Its the only idea i have for you sorry. New motors sometimes need a little breaking in.
01-12-2010, 01:46 PM | #3 |
K I will try that and post back |
01-12-2010, 02:11 PM | #4 |
oh and dont let the wheels free spin they need a small load on them when you do this. Just drive it on the ground for the 15 mins.
01-12-2010, 02:16 PM | #5 |
OK, I ran it resting on my knee with the rear tires rubbing my leg just a tad for some load until the motor was real warm and so far seems to have set the brushes. I'm gonna put it all back together and run a few packs and report back in a few. thanks, Brent |
01-12-2010, 02:36 PM | #6 |
cool glad it seemed to work.
01-12-2010, 02:51 PM | #7 | |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
Report back with how it works out. I've got a mini torque master on the way and would like to avoid any hold ups. | |
01-12-2010, 03:36 PM | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
I just put the new 22t in mine and have had zero issues with it so far.. Sweet motor...
01-12-2010, 04:30 PM | #9 |
Ok I have now run 2 packs and so far no more issues.....now if the sidewinder esc and castle link show up before this weekend I will have good odds at the comp. The holmes motor is sure a great upgrade, plenty of power and torque! |
01-12-2010, 04:32 PM | #10 |
01-12-2010, 05:36 PM | #11 |
01-13-2010, 09:24 AM | #12 |
01-14-2010, 04:16 PM | #13 |
Quarry Creeper Join Date: Jan 2007 Location: Raaaaaiiiiinnnnniiiieeeerrrr
hey mrblue, im in oly, wa. are you a member on the warcrc board? |
01-14-2010, 04:49 PM | #14 |
01-15-2010, 11:58 AM | #15 |
| no I only compete in the scale comps. just had one last weekend at the slab. you comp guys is crazy haha. I wish I had the time and an endless budget to build a sweet moa rig like rokpile has. when rocky and i meet at the skook to practice he lets me drive his moa rig and it is fun. . I might show some day with a 1.9 comp rig to see that end of the hobby. i did tell devlin and rocky I would build a comp rig if rocky built a scaler. so now im in for it haha.
01-18-2010, 10:35 AM | #16 |
Well, the stall is going to piss me off, killed me on all 3 courses at the comp, One guy said that I should get the silver brushes and this will fix the prob......Why dont these come already installed if this has been a recurring problem? |
01-18-2010, 10:40 AM | #17 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
Hey contact John and i am sure he will help you out, his customer service is next to none. He stands behind his products. Sounds like you prob have some other issues going on.
01-18-2010, 12:14 PM | #18 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
How hot is the esc getting? If you still have the stock motor you could put that back in to see if it still stalls.
01-18-2010, 02:34 PM | #19 |
Rock Stacker Join Date: May 2009 Location: Jacksonville
I am about to pick one of these up as well as I burnt out the stock motor this weekend. Time for upgrade. I have a stock esc is that what you guys are running with this motor? or have you upgraded? Is there any problems running this motor with a stock esc?
01-20-2010, 09:34 AM | #20 |
Update: I removed the motor and sprayed it out with electrical cleaner/lube,then a little air and let it dry....problem seems to be solved |
