Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Anyone running tekin FX-R & 3S lipo?
Old 02-19-2010, 03:27 PM   #1
Default Anyone running tekin FX-R & 3S lipo?
I am running the Tekin FXR and a 3S lipo. The motor is a Holmes Hobbies Torq Master Mini. The ESC temps are warmer than usual, about mid way on the ESC temp guage. Stock Spur and a 12 tooth pinion. Has anyone had any issues with this type of setup? Tekin claims the ESC can handle 3S with the use of a 35 turn or higher motor. I figure the HH TMM is a high turn motor and since its a 280/300 size motor VS. a 540 things should be OK.
it8ezbngrn is offline   Reply With Quote
Old 02-19-2010, 03:30 PM   #2
The HH Torquemaster Mini is 33t or 22t depending on which version you got.
Crawl_Before_Walking is offline   Reply With Quote
Old 02-19-2010, 03:37 PM   #3
dnf
rock hard's Avatar
you should have no worries with any 380
a fxr can handle 2 35T motors with 3s
I would want to make sure all connections are good 1st
also the capasitor must be installed.
other than that?
how was you running it?
balls to the wall?
rock hard is offline   Reply With Quote
Old 02-19-2010, 03:39 PM   #4
I'm still guessing that the overall current draw is equal to or less than a 540 size 35 turn motor. The temps only heat up when I'm full throttle but it does heat up quickly. Reason for 3S was to give me a wider range of RPMs to work with. To it give it more crawl ability and less strain I went down 2 teeth. The motor is at 0 degrees timing.
Old 02-19-2010, 03:41 PM   #5
I run the TMm and a sidewinder micro esc, 12t pinion and stock spur and i use NIMH batts at the moment and have no issues at all, good wheels speed and torque and great slow speed control for creeping.
Old 02-19-2010, 03:46 PM   #6
The cap is installed. I am also running two Hitec 645MG servos (not full time 4WS). Yeah when I keep it slow the temps are low. Real low, like it was with 6 cell Nimh. But as soon as I run flat out for a few seconds it apears to get warm and jump to half way or just under. I was concerned cause I've never seen it get warm before. I was running two 6 cell 1100 mah packs in parallel (2200mah 7.4V) Now I'm runiing a Venom 3S 1300 13C lipo. It was cheap and small. Cheaper than buying one nimh. May add a Novak LVC with LED just to be safe. Worried while crawling that I won't catch the Tekins LVC notifications. I haven't even ran this pack down yet. Just did some preliminary testing.
Old 02-20-2010, 12:10 AM   #7
well if your running a lipo and your constanly on the gas (as far as the triger will go ) then it will heat up... ive been through 5 stock escs and just ordered a tekin fxr but watch your speed... their crawlers ;) hahha if your not speeding then its your motor maybe..
shadowrejects is offline   Reply With Quote
