04-08-2010, 10:43 AM | #41 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
If you used something smaller in diameter for your drag link and tie rod, then I think you should be able to mount your drag link on top of the knuckle arms. I've drilled and tapped my aluminum knuckles for 0 ackerman angles. All my links are further above the knuckle arms
04-08-2010, 12:24 PM | #42 | |
04-08-2010, 12:31 PM | #43 |
Um.. I don't have a pic showing the front view. I'll try to remember tonight. I will tell you what I'm using for tie rods. 1/8th music wire That stuff is strong. For what little lenghts you need to use, there's not hardly any flex. You can flex it, if you try like hell. But it's got memory. Also I've got about 2.5mm spacer between my knuckle arms and tie rod. Puts it up high. I shaved the housing alot to make fit |
04-08-2010, 12:32 PM | #44 | |
04-08-2010, 12:50 PM | #45 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
I have some solid steel rod that will work,I'll bring it with me and we'll whip some thing up real quick for you steering. |
04-09-2010, 03:20 PM | #46 |
04-09-2010, 03:26 PM | #47 |
After spinning out a pin in one of driveshafts just zipping around the house I knew that they needed to be upgraded. After a little searching I came across this mod that Eric113 posted. I already had some stampede shafts and balls laying around so I just spent $10 at my lhs and after I had some beefy shafts. Here is a link to Eric113's post eric113 GC2 When I was running a shafty in the 2.2 class I had a problem with twisting driveshafts. I didn't want to upgrade to MIPs because I liked how the plastic shafts were a weak point. I still wanted to stiffen them up a bit and Corkysk8 mentioned that 8-32 all thread was a perfect fit in the Traxxas shafts. It's a cheap way to have some super strong driveshafts Last edited by helhedded; 04-09-2010 at 03:28 PM. |
06-07-2010, 01:16 PM | #48 |
Well Lil Focker has been lots of fun. We have experienced a few hangups here and there such as: blowing a tranny locker at ECC, lil focker being so thirsty that he decided to go for a swim, lil focker eating up both sets of axle gears... you know Fast forward to the last Ark/la/miss comp that we had last weekend. My buddy Rottenbelly hooked me up with some wheel wideners. I just wanted them on the front to see if it made a positve performance gain. The way the truck ran was so much better compared to before. I also added an ounce to my back axle. The truck stays planted more now. I ended up in 3rd place, but points were tight. The more and more I drive this lil focker, the more I love it. It's been a rough trip Lil' Focker, but I won't give up on you. I probably just need to tone down your lipo power. I upgraded to some Vendetta Shocks. They are very smooth and the red compound HB Rovers and Lil' Nova foams are a killer combo. Last edited by helhedded; 06-07-2010 at 01:22 PM. |
07-21-2010, 02:17 PM | #49 |
I recently put on a JR8711 servo due to my Hitec 5645 feeling too weak. I am really glad that I put this monster on because the last thing you need is your servo stalling out when you have no dig. I also siped my Rovers. I'm not sure why I didn't so this a long time ago. The 8711 @6.0v has no problem doing what I tell it do I had to turn my tranny around to allow more room for my battery...talk about cramming 5 lbs of crap in a 2lb box.... |
07-21-2010, 05:31 PM | #50 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
Nice mod for the shafts. Looks like I'll add that and turn the trans around to my list of things for my son's GC3 build. I'll have to post some pics when the cvd's arrive this week and start building this lil turd.
07-21-2010, 11:22 PM | #51 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
So how much wider did the wideners make it?
07-22-2010, 06:53 AM | #52 | |
They pushed my front out to 8" wide. I'm not sure on the measurement before the install. | |
07-22-2010, 03:29 PM | #53 |
Here are a few pics that show the difference from the front to the rear. It seems to really help with the turning radius. |
08-02-2010, 07:03 PM | #54 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Great build! I thought about putting my 8711 in mine but need to upgrade some parts first,that's a lot of servo for these little trucks!! What's it weigh with the battery and all ready to hit the rocks?
08-02-2010, 07:25 PM | #55 | |
Yeah it is a lot of servo power for sure but I haven't broken anything... yet I just threw it up on the scale RTR with a new Rhino 360 mah 2s (tiny) and it weighed 2.75 lbs. I really need to move the electronics down lower... I really don't like how everything is at the moment. I'll probably end up flipping the tranny back around so I can have more space in the back. | |
08-02-2010, 07:31 PM | #56 |
Pebble Pounder Join Date: Oct 2009 Location: in a state of labyrinth
This lil focker rocks. It amazes most everyone when he takes it out. That looks like the same place my 2.2 cooled off last comp. Great lil' rig Ashton can't wait to drive when you get it out again |
08-02-2010, 07:41 PM | #57 | |
I'll let you drive it, but when will you build your own so we can start running these things at 4WP? | |
08-03-2010, 04:53 AM | #58 |
Rock Stacker Join Date: Jul 2010 Location: Tampa
Nice build nice to stare at and be a dreamer
08-03-2010, 06:05 PM | #59 |
Newbie Join Date: May 2010 Location: Anza
| helhedded GC3
To helhedded, Nice build, excellent photos and thanks for all the useful information. bens170 |
08-23-2010, 12:30 PM | #60 | |
| Thanks! Quote:
small update: more belly clearance! ..not too sure if the shocks will stay like that, but it does help with sidehilling. FYI, I only had to stretch the stock gc3 links by 1mm to get them back to the correct length. The uppers will work in the lowest hole. You just have to rotate the lower links inward a little. I also have my shocks limited by 1/4", so that is why I am not seeing any binding. Last edited by helhedded; 08-24-2010 at 01:14 PM. | |
