02-11-2011, 10:48 PM | #101 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Ashton, let me know how you like the 4" rovers on your lil' focker. I have been thinking about getting Eddie to make me some but I haven't even tried the stock rovers on mine yet. I am still running my super soft cobra's. Truck is looking good by the way. |
02-11-2011, 11:09 PM | #102 |
Rock Stacker Join Date: Jun 2010 Location: Springdale
Thanks and how did you do the rod end mod? It would make life a lot easier.
02-11-2011, 11:47 PM | #103 |
Rock Crawler Join Date: Jan 2009 Location: Great NorthWest
Nice lookin rig Can we see your knuckle weights..........up close |
02-12-2011, 08:13 PM | #104 | |||
-mount the shock in a vice (not absolutely necessary but recommended) don't clamp your shock too tight... -cut off the mounting holes on the shock caps with a hack saw or dremel -smooth the top of the cap with a file -drill a 2.5mm or 3/32" hole in the middle of your shock cap -tap the new hole for 3mm -make sure no metal shavings are in your shock bodies -blue loctite a 3x8 button head and bolt it into your cap -add shock bladder and oil -install rod end and enjoy Quote:
oh you mean these I threw these together a couple weeks ago. They are ugly as hammered shit but they get the job done. I bought the washers from Northern Tool and I just used .5oz and .25oz lead weights. Total weight of one is 1.9oz. That bronze washer was is a real pita to work with. I don't run a huge hex anymore so I had to put the weight on the inside of the knuckle. Last edited by helhedded; 02-12-2011 at 08:26 PM. | |||
02-12-2011, 09:33 PM | #105 |
Here is a sweet shot that my buddy TC took today at the comp |
02-12-2011, 09:37 PM | #106 |
hey, that knuckle weight setup looks gross. Probably works though. Guess they were good enough for the 1.9 win today. |
02-12-2011, 09:41 PM | #107 | |
Hey you motivated me to get it done when you told me that you made some for your mini I wish that you could have made it. It got kinda nasty at the end. | |
02-12-2011, 10:04 PM | #108 |
| Looks good! My 1st set looked much worse |
04-25-2011, 02:53 PM | #109 |
Well just as an update I took this truck to ECC and finished in 12th. The only thing that hurt me was the body pins and mounts sticking out of the body. They really fubared my runs once I was on my lid at LRC. I don't have any updates other than I"m back to running an up-front tierod. I lost a TON of servo power the other way. too many angles |
11-08-2011, 12:44 PM | #110 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
11-08-2011, 12:50 PM | #111 | |
| Quote: Yep, Lil Focker is in the process of getting parted out. It was fun but it's time to move on to bigger things. http://www.rccrawler.com/forum/sale/...%24e-look.html | |
11-08-2011, 04:57 PM | #112 |
