Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: suggestions for cheap mrc motor
Old 04-25-2010, 04:54 PM   #1
Default suggestions for cheap mrc motor
my stock mrc motor is getting hot and just needed suggest for some thing to replace it with that is as cheap or cheaper than the stock one thinking about frenzy 370 0r the rx280 from losi
gofaster427 is offline   Reply With Quote
Old 04-25-2010, 05:03 PM   #2
Dude the frenzy has been sick so far, no cogging, nice torque, fast wheel speed, and I can't find anyone else running it , but you need larger diameter bolts to mount it and drill out the holes in the mounting plate to line up with the holes in the frenzy motor. The stock pinion can be used if you turn it around and grind off some of the length of the pinion. $13 for the motor . I'm editing a video now .will be up soon .
droopmodmrc is offline   Reply With Quote
Old 04-25-2010, 05:34 PM   #3
Mini torque master, I used a fireball micro for about a month (burnt up in a month)
ixer is offline   Reply With Quote
Old 04-25-2010, 06:02 PM   #4
if you are picking between the two i have the Slider motor in mine and it ups your wheel speed alot. but if you upgrade to this motor invest in the metal tranny gears. I just striped all of mine at a comp today.
KnightRyder is offline   Reply With Quote
Old 04-25-2010, 06:22 PM   #5
that sucks to hear about the gears but I have already got one extra set and how long had you had it with plastic gears
Old 04-25-2010, 06:34 PM   #6
I run a Sportwerks E-Racers motor on mine. It was < $12 at the LHS and is a great balance of torque and wheelspeed.
EvilTwin v2 is offline   Reply With Quote
Old 04-25-2010, 06:43 PM   #7
did you have to do anything special to install it
Old 04-25-2010, 06:50 PM   #8
is this a direct bolt in
Old 04-25-2010, 07:09 PM   #9
Nope.
Old 04-25-2010, 07:58 PM   #10
Default Video of Frenzy 370
Here is the Frenzy 370 in action. First I show the low speed control then the drag brake and finally the power and wheel speed.
http://www.youtube.com/watch?v=0Qm__VUb0nY
Old 04-25-2010, 08:23 PM   #11
It is but for you to put the stock pinion on you either have to drill out your pinion gear, or sand down the motor shaft
Old 04-26-2010, 02:49 PM   #12
well I used the slider motor and broke my integy center drive shaft not sure if it was bound up or just weak
Old 04-27-2010, 07:53 PM   #13
the intengy drive shafts from what ive read and what ive seen are week. i use the traxxas drive lines that are way better they are plastic but hold up way better than the stock ones and alot of the metal ones. The only thing i would say to change is the tranny gears. To swap them to metal...
Old 04-27-2010, 08:20 PM   #14
Had the TMM In two cars and now one of his handwounds in my 2.2s. Cant go wrong with Holmes' motors and they are priced pretty darn good...
http://holmeshobbies.com/home.php
dickwart is offline   Reply With Quote
Old 04-28-2010, 12:37 PM   #15
I just put a venom fireball in mine,Runs real nice now,no heat,faster with more torque as well.
Good motor ,and $16 nz,nice and cheap.
vipxj is offline   Reply With Quote
Old 05-12-2010, 10:18 AM   #16
Git
i just installed a tamiya sport-tuned 370 mabuchi on mine.. usd13
the speed and torque are quite impressive. had to dremel the mounts on the mrc though. the tamiya had wider mounts.
Git is offline   Reply With Quote
Old 06-12-2010, 12:37 AM   #17
i stole a 380 motor out of my 20+ mph nikko i had laying around, lol havent thrown it in there yet... but its the same size and same mouting pose, lol
shadowrejects is offline   Reply With Quote
