06-15-2010, 07:58 AM | #1 |
Newbie Join Date: Jun 2010 Location: North New Jersey
| Free Mods...
just wondering if there are any free modifications i can do to get this to crawl better. sometimes it just flips over on its roof.
06-15-2010, 08:28 PM | #2 |
Newbie Join Date: Jun 2010 Location: soddy
There is alot you can do 1 Lower your COG (center of gravity) by moving things lower on your chassis 2 Add weight in your tires and while your at it make them true bead locs its cheap and easy take a piece of 2 inch I.D. pvc and cut it to a length of .750 or 3/4 inch 3 Run droop put springs on the inside of the shock to pull it down instead of pushing it up. 4 Put your battery on the back axle. 5 Get rid of any unwanted weight that is up high kinda goes along with #1. 6 Position your body down lower so it looks like the cog is lower. 7 Look around on the forum you will find alot to do. Hope some of this helps |
06-15-2010, 11:05 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Start with The Beginner's Guide that is a "Sticky" at the top of this MRC forum; it details what DoubleD listed above and more. Read all that, first.
06-16-2010, 12:04 AM | #4 |
RCC Addict Join Date: Mar 2010 Location: Yelm
You pretty much dont even need to know what you are doing. If you search enough on here, you could build a VERY capable rig on the cheap. Lots of expensive lessons on here that you dont have to pay for. |
