09-17-2010, 07:16 PM | #21 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
Wow! So just over 1/3rd of the rigs total weight is the two front wheels!
09-18-2010, 03:52 AM | #22 |
Ok so I ended up making some 1.9 Boss claws and took the rig out for the first time tonight. Im not sure if it is a suspension setup thing or a tire/foam thing but anytime I hit a ledge with the fronts or rears they just bounce like crazy. I made mine a little different than you made yours, mine use the whole eclipse tire (shortened) with the sidewall from some comp claws (should have looked at your pics more closely before cutting). What would you change first? Also I tried setting my links up like yours and the fronts seem to bind on the front edge of the chassis...Any tips on how your setup is working? |
09-20-2010, 08:30 AM | #23 | |
Newbie Join Date: Jul 2010 Location: Ridgecrest
09-20-2010, 11:52 AM | #24 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
I've built a set with Eclipse buggy tires in the green compound, but they didn't work very well. If you use any of the 1/8th scale buggy tires, be sure to remove the inner webbing from the tire. The webbing keeps the tire from flexing the way it should. | |
09-20-2010, 01:42 PM | #25 |
You convinced me. I just called and changed my order from green Eclipse to red Boss Claws. The green Eclipse were back ordered anyway. I guess we will see how the Boss Claws work out.
09-20-2010, 02:14 PM | #26 | |
You'll probably have to remove a row or two of lugs from the center of the tire to make them narrow enough to work as a 1.9. The red compound will work out great though | |
09-20-2010, 06:49 PM | #27 |
no talent hack Join Date: Feb 2007 Location: Redwood City
setup looks familiar. hahaha
09-20-2010, 08:25 PM | #28 |
09-20-2010, 08:43 PM | #29 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
That mini is choice |
09-21-2010, 02:31 PM | #30 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Just got my eyes on one of the se for the first time today at the lhs. Very cool truck. I do notice some big differences between this truck and the GC3 but I also see a ton of similarities. That being said I would love to get my hands on a front trey!
09-23-2010, 04:45 PM | #31 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Is that aluminum C's and zero ackerman knuckles I see on the front? When can we expect to see the zero ackerman knuckles in aluminum for sale?
09-23-2010, 05:13 PM | #32 |
09-23-2010, 05:32 PM | #33 |
I just saw this at the LHS about 20 minutes ago....SOOOOO tempting!! I haven't read up much on this thing, so as soon as I got home, I checked out the MRC section. Damn it...I have a funny feeling this truck will find it way into my basement |
09-23-2010, 07:00 PM | #34 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
I pulled the trigger on one. Really nice in the fact you dont have to do alot to the rig. Just slap on some electronics and win. |
09-26-2010, 08:34 AM | #35 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
talk some more about the losi setup. Is there any other setup you can compare it to? I was looking at the novak mongoose even though i am not a big fan of novak. Are you able to stall it ever or will you snap\slip before you do? |
09-27-2010, 11:34 AM | #36 | |
The drag brake seems more consistant than the other brushless stuff out there too. | |
09-27-2010, 11:43 AM | #37 | |
Del Monte, you got any video of your MRC Pro running? I would love to see that little 1.9 do some work! | |
09-28-2010, 07:49 AM | #38 |
| Jake, can you provide any more information about this? What o-ring? Where did you place it? Base of the cartridge at the bottom of the threads??
09-28-2010, 11:48 AM | #39 | |
The new cartridges were a running change show they should already be showing up in the new shock kits. | |
09-28-2010, 12:23 PM | #40 |
Thanks for the info. What type of o-ring are you using? It sounds like you put it inside the cartridge, is that correct?
