Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Rubba's MRC PRO Half-Pint
Old 09-25-2011, 10:26 AM   #81
ok, so here's a question i have been wondering about, does the MRC Pro use more 3mm screws than 2.5mm ones? also, i am planning on ordering one, and maybe the novak mongoose set-up, which says it use a standard size pinion, is it ok to use a stardard sized pinion with this spur gear? and what is the pitch? i looked through the manual off of losi's site, and it doesn't mention in it what pitch the gears are.
STEEL_CITY_CRAWLER is offline   Reply With Quote
Old 09-27-2011, 11:59 AM   #82
WAM
I see no reference to tires. I guess if it doesn't start with "L", you're not supposed to talk about it?
Actually, I'd like to start comping with the blues because I have a bunch of them. Can I get closer to the "R" tire capability with siping and some attention to foams?
WAM is offline   Reply With Quote
Old 09-27-2011, 04:07 PM   #83
The Team Losi blue rovers work well, with siping and proper foams(Crawlerinnovations) medium front and soft rear.
The rovers just seem to hook better. That's just the down and dirty of it.
Rubbaneck-anything new on this setup? I am sure people are copying this thing all over the place.
xgerstandtx is offline   Reply With Quote
Old 09-27-2011, 09:07 PM   #84
On his website he suggests soft front and medium rear, why do you run them the other way? (I'm not trying to be sarcastic or anything, I really want to know your reasoning)
Link: http://www.crawlerinnovations.com/in...mart&Itemid=63
VotebanForgotHisPW is offline   Reply With Quote
Old 09-27-2011, 10:00 PM   #85
WAM
Did you mean to say Team Losi blue Rock Claws, instead of blue rovers?
And did you mean to say soft front and medium rear?
Old 09-28-2011, 05:59 PM   #86
Yes and 48p.
wild bill is offline   Reply With Quote
Old 09-29-2011, 12:50 AM   #87
You are right, i meant soft up front and medium in the rear, this is also what i use. It was a late night and i messed up the info,sorry
Damn and i meant to say blue CLAWS. wow... I'm gonna go get some sleep now
Old 09-29-2011, 08:15 AM   #88
WAM
That's okay, we knew what you meant.
Old 09-29-2011, 08:48 AM   #89
Originally Posted by wild bill View Post
Yes and 48p.
They are not 48p FYI Check out this link for Robinson Racing products for the correct pinion pitch http://www.robinsonracing.com/catalog/rc18tmini.html
I won the Worlds with Losi Blue Rock Claws, still a great tire. The 2010 Nationals I ran rovers with stock foam. There is no need to buy different foams for the 1.9 class. Just run the stock and you'll be fine and also save a few bucks.
Nothing new at all .... well maybe some cobwebs
Rubbaneck is offline   Reply With Quote
Old 09-29-2011, 07:46 PM   #90
WAM
Originally Posted by Rubbaneck View Post
[B]I won the Worlds with Losi Blue Rock Claws, still a great tire. The 2010 Nationals I ran rovers with stock foam. There is no need to buy different foams for the 1.9 class. Just run the stock and you'll be fine and also save a few bucks.
Good to know about the blue's capabilities. But your other comments referred to the Rovers. On the Losi blues, did you run them full tread with stock foams or was some tweaking involved?
Old 09-30-2011, 08:20 AM   #91
Take a look on the first page in the first set of pics. Halfway through the claws are on aluminium rims. You'll see how I chopped them up
Old 09-30-2011, 08:59 AM   #92
WAM
Thanks. Actually I can't see much on my laptop, but I can import them and blow them up.
Old 10-21-2011, 02:28 PM   #93
you guys crack me up! Thanks for the props too.
And now for some update's. Ran the Pro for a while stock then just started tuning it for the Colorado 2010-2011 Winter Series.
Front Suspension
Upper Track Rod: #5
Shock Arm Position: B
Shock Mount Position: #1
Shock Oil: Losi 42.5wt.
Piston: Stock 3-hole
Inner Limiter: 10mm
Outer Limiter: 3/32"
Spring: LOSB1119 Silver Soft Mini-T rear springs with no preload
Rear Suspension
Upper Track Rod: #5
Shock Oil: 42.5wt.
Piston: 3-hole right rear with no preload, 1-hole left rear with 1/4" preload
Inner Limiter: 10mm
Outer Limiter: none
Spring: LOSB1447 Stock MRC RTR springs
High Clearance Losi links rear only Horizon Hobby: Lower 30 Deg High-Clearance Susp Links, Alum: MRC by Losi (LOSB1416)
Front and rear shocks are outboarded with LOSB1446 Outboard Shock Mount kit.
u still running / liking this set up or have u changed some stuff around if so updates plz
lowridinjuggalo is offline   Reply With Quote
Old 10-21-2011, 02:36 PM   #94
What he said Im currently redoing my 1.9 and looking for some guidance on a base setup.
DRCrawlGood is offline   Reply With Quote
Old 10-21-2011, 07:35 PM   #95
A couple posts up, Rubbaneck said he is still using the same setup.
Slaughter is offline   Reply With Quote
Old 11-18-2011, 02:28 PM   #96
I want to thank you for all of your info. Great stuff.
new2this is offline   Reply With Quote
Old 12-28-2011, 05:16 AM   #97
Default Re: Rubba's MRC PRO Half-Pint
Great info here
Nik
Nik6189 is offline   Reply With Quote
Old 12-28-2011, 08:08 AM   #98
I'm glad to see this thread updated...very helpful stuff.
lenage is offline   Reply With Quote
Old 12-28-2011, 03:10 PM   #99
Until I read this last night I was thinking of changing chassis, but I might just keep the pro and set it up like this. Just got get rid of the damn torque twist and leaking shocks..
Nik
Old 12-29-2011, 12:21 AM   #100
Really like this thread!! I was working on mine on the desk wile reading your set
up lol. Really like this set up and grate info!
muddauber jr is offline   Reply With Quote
