11-10-2010, 10:55 PM | #1 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| RcBros New Season Pro Build
Well new season, means new truck. I've missed two comps, so I needed to kick it into gear. I decided to start out with the new Losi MRC Pro and then tweak it to my standards. The Pro version comes stock with lockers and front CVD's. But I decided to kick it up a notch by adding the front over drive mod. Losi stock pinion on left, traxxas pinion on right. Next up I decided bent rear links were needed. So I cut, threaded and bent up some rear links. My main goal was to come up swith a BTA steering setup. So I first added our RcBros front 4 Link mount, High Steer Knuckles and High steer link. I then added a Futaba S9511 low profile servo, and added some new custom upper links. Nice approach angle now. The BTA was easier then I expected. I simply flopped carriers from one side to another, and adjust my upper links for clearance. Everything is very tight, but I feel it should work great. It may have a tad to much negative caster, but we'll see after testing. |
11-10-2010, 10:58 PM | #2 |
Next I wanted to try something I've never done before. Cut n shutting tires. I swore I'd never do this, but I suckered myself into it. After seeing how well the 2.2 boss claws preform, I decided to create a knock of 1.9 set the best I could. 1.9 Flat Irons, and Short Course M4 Caliber tires. I first started by cutting the sidewalls off a 1.9 flat irons. If you look at them closely, they have a nice mold line on the outside of them. I followed this line. Then, cut the centers of the calibers. And then alot alot alot alot alot and alot of patience, some good glue, with a straw tip and more patience. Then mounted up on a new set of Vanquish wheels. After having them mounted, with a ton more patience and everything I could mustard to still work on a tire I'm questioning, I cut away at the tires until I felt I had something that should hook up well. we'll see how they preform... |
11-10-2010, 11:05 PM | #3 |
RCC Addict Join Date: Jun 2005 Location: Prosser
Those tires look great William! Not too shabby for a first time cut job. Truck looks great too, nice job on the steering! |
11-10-2010, 11:22 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
Looking good William! You are right, the tires do look big.
11-11-2010, 12:23 AM | #5 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
woah, with the vanquish and the caliber, it kinda looks like a XR-10, if you just let your imagination kick in alittle! very nice build! BTW, do you happen to have the part number for the traxxas pinion? thanks |
11-11-2010, 02:56 AM | #6 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
11-11-2010, 04:18 AM | #7 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
Very nice build. Those steering knuckles look very svelt, as do the cut and shut tyres. Just wish I had the skill and patience. Isn't it about time one of the big manufactures picked up on the fact that the pros are making these tyres and manufacture them for the mass market? I'd be all over a set. |
11-11-2010, 08:42 AM | #8 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Very interesting build really like the tires lets get er dun and see it perform
11-11-2010, 08:54 AM | #9 | |
Pebble Pounder Join Date: Aug 2010 Location: Roseville
11-11-2010, 09:11 AM | #10 |
| You just need to purchase a pinion gear from a mini slash. This gear is a direct fit for the MRC and has one more tooth than the stock pinion. The part number is pictured above. Let's see some more pics of the BTA. I've been running mine with your servo mount for quite some time now and am pretty happy with the setup! Nice work on the tires! How tall did they come out to?? |
11-11-2010, 09:55 AM | #11 |
oh, thanks! is the traxxas pinion more durable than the stock pinion? i mean $10, for the pinion is alittle high from my perspective.. |
11-11-2010, 10:06 AM | #12 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
Great looking build. I think next mod to the buggy is over drive. Tires look great!
11-11-2010, 10:07 AM | #13 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
nice job so far have you had a chance to run it since all the mods
11-11-2010, 11:08 AM | #14 |
11-11-2010, 11:18 AM | #15 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Cool build. Nice work on the cut n shut tires as well. I don't think you are going to like the height of the tires on the 1.9 though. In my testing I have found that 4 1/4 is too tall for 1.9 competition. If the rules would allow for a longer 1.9 wheel base they would be perfect though. I have been making 4" tall 1.9 comp tires lately and that has been working out pretty good. What did you end up using for foams in these tires? |
11-11-2010, 12:15 PM | #16 |
11-11-2010, 12:24 PM | #17 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
now i have some new ideas for my mrc
11-11-2010, 01:44 PM | #18 |
Yes, I'm not happy with the tires at all. They did not seem large until I installed them, kicking myself hard, I forsee cutting them up to reduce the size once again.
11-11-2010, 02:49 PM | #19 | |
11-11-2010, 02:55 PM | #20 |
