11-21-2010, 10:27 AM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: Roseville
| Vanguish Wheel Question
I just bought some VP LH wheels from someone here. My question is why is the diameter of the the hole that my axle goes through is a bit larger than my axle. Is this normal? Or do I need special wheel nuts?
11-21-2010, 12:06 PM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
You don't need special wheel nuts but you may want to run a washer before the wheel nut. If you plan to run wideners such as the http://www.tcscrawlers.com/2.2-Wheel...g-p-16233.html G-Made you will be glad of the extra diameter to allow the grab bolt to fit the wheels. Nice wheels by the way |
11-22-2010, 01:37 PM | #3 |
Newbie Join Date: Oct 2009 Location: Chandler, AZ
Where did you pick up your Vanquish LH procomps? I can't seem to find a set anywhere. I'm sure it doesn't help that i'm a noob, but I can't find any good aluminum beadlocks. Also, anyone know if the proline super swampers fit on the LH procomps? Thanks
11-22-2010, 01:42 PM | #4 | |
RCC Addict Join Date: Aug 2008 Location: Charlotte, NC
You can also purchase any of your VP needs through T1E www.t1erc.com | |
11-22-2010, 02:55 PM | #5 | |
Rock Stacker Join Date: Sep 2010 Location: los angeles
you can check ckrccrawlers also for vanquish wheels. they might be outta stock :( | |
