11-27-2010, 11:22 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
| My almost comp crawler
Well for my first crawler I chose a mini and here are the specs and pics Stock esc Stock wheels Stock rx/tx (Until Christmas) 1 stock driveshaft 1 aluminum driveshaft (I screwed the other one up) 1.9 Mud Slingers (Until I get the money for rovers) Stock body 10 tooth pinion gear aluminum spool gear Droop setup for now GC-3 Chassis Stock Servo (When my BEC comes in ill have a torque master) aluminum diff gears Stock motor |
11-28-2010, 09:31 AM | #2 |
Newbie Join Date: Oct 2005 Location: nw
looks like a good start. mudslingers sure "look" good.
11-28-2010, 11:13 AM | #3 |
Drop your esc and rx down to the upper links,that will help lower your cog some. I would also try limiting your articulation a touch. I like my front axle to have a touch more droop that the rear. And try for 35-40* of articulation and see how much more predictable your truck becomes. |
11-28-2010, 11:28 AM | #4 |
im got new springs coming to go back to normal rideheight to see how i like it and i need to tack the cut end of the spring together cause they keep wraping around the spacers and i figured out today the stock tires work much better
