RX/TX Help!!!! I got my crawler a month ago and my stock controller and reciever woulnt bind I have to leave the bind pin in it to get it to work each time and it still takes a couple trys to get it to work. I am getting a new tx for christmas and I dont know if it will help with this problem or not if it woulnt then I will just buy a new rx. Anyone else have this problem |
Can't help much i'm afraid as i'm using a different Tx and Rx. I did give the Losi one to a mate though to use in his drifter/touring car and he's had no problems. Might be worth sending Losi a email, they seem pretty good on customer support "thumbsup" |
Just for clarification, you have followed this bind procedure: 1) insert bind plug into proper port on Rx 2) Turn on Tx, then turn on car 3) select bind on the Tx 4) light on Rx should turn solid 5) Turn off car, then turn off Tx 6) remove bind plug 7) turn on Tx, then turn on car After this, everything should work properly, assuming you have calibrated the ESC. You should never leave the bind plug in the Rx... |
I had the same problem with my MRC when i first bought the RTR. After a week or so I returned it to the store i bought it from and they gave me a brand new truck. Never had the problem again. |
two of my mates MRCs have a similar problem. One is bad everytime switched on, the other every now and again. not sure why as it is all spektrum electronics. RX are SR300 i beleive. My MRC stock RX and TX never gave any problems bind wise. But the transmitter's steering wheel started glitching due to worn pot (after 18months use!) replaced with DX3E works superb with stock RX. I agree, try returning - maybe faulty radio electonics. |
