11-30-2010, 12:12 PM | #1 |
Newbie Join Date: Jan 2010 Location: redlands
| bec question
so im lacking the power to my servo, and i have a BEC from my sc10's novak electronics, my question is can i just use that on my MRC with stock ESC and receiver? heres a pic of it, im sure its the 3-Amp High-Voltage Universal BEC thx guys |
12-01-2010, 05:18 AM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Should be fine, i fitted a CC BEC last week and it made a noticeable improvement to the steering torque. A quick search should bring up various wiring diagrams, on mine though i soldered the input leads to the deans battery connector and plugged the output leads into the 3rd channel (not used) of my Rx. If you do this you need to remember to pop out the power lead on the Rx coming from the Esc. Don't cut it as you might well need it, just pull back the very small tab on the connector and slide out the pin. Also remember to wrap it in heatshrink of insulating tape as it is a live wire Cheers Mark |
12-06-2010, 02:13 PM | #3 |
sweet, thanks!
