12-05-2010, 10:55 AM | #21 | |
and it meshes real good. the losi pinion is 48 pitch I went to lhshops and studied various bevel gears. Nothing really caught my eye though. Now I'm not a heli guy but I think its called a tail rotor gear,its a bevel gear but wrong material,though I will constantly be looking for additianal options. But hey,either way. Underdrive will be on a course near you soon,and they will only be improving from here on out. That along with the other inovative offerings from within our rcc community, and you know this is gonna be a great season for the 1.9 class Last edited by rock hard; 12-05-2010 at 10:57 AM. | |
12-05-2010, 11:01 AM | #22 | |
set screw problem is not really a problem | |
12-05-2010, 06:30 PM | #23 |
CrawlerMafia Underdrive mod I again will layout the methode I used here for you. Below will show how I use a 12t bully pinion with the right teeth(chamfered) The only problem with this mod is I cant find these pinions in 12t anymore. But if you happen to have some,you can put them to use,or pm me as I would love to have them. For starters I take a bearing from the axle and head to the garage to find me a drill bit that fits the bearing. Then I find me a long 3mm bolt for the grub hole. I have found this makes working with the pinion much easier. Now I grind the bottom of the pinion just as close as I can to the grub. I use a bench grinder for this.( see above pic ) Try not to let the pinion get to hot,so go for a bit then cool. This isnt for your fingers,its best for the pinion itself. If it gets to hot it could weaken the material. So avoid using pliers and going gun-ho on it,take your time. Dont worry about getting it perfect,you can fine tune it with the dremmel for the final touches. Now I use the dremmel to cut the pinion down. I cut at 6mm,then use the dremmel to get it down perfect. It will be around 4.5mm when its done. Now I use the drill bit to drill out the pinion. I will place it in a vice for this. Once drilled I place the pinion on the drill bit,and I'm looking to get the drill bit all the way within the pinion,like shown The reason for this is I want alot of contact between the new output shaft and the pinion. Yep thats right,that drill bit is about to be your new ouput shaft. With the pinion in place I mark the back,then decide where I will grind my flat for the grub. Then I just use the dremmel to make a flat like so Now I cut the drill bit to my desire length and make a flat for the drive shaft then I mount the pinion onto the shaft,so its easier to hold for touching up. I then use the dremmel to open the teeth at the back a touch,and then go over the pinion with a wire brush on the dremmel to clean it up. I would say your looking at 3 hrs totall time. I place the pinon in the case with ring gear ontop,I then spin the gear slowly, any place that feels to rough I clean up. The grub will hit,just put your wrench in it and use the dremmel to grind it smaller. When it was done it looked like this 12t pinion with new output shaft Last edited by rock hard; 01-27-2011 at 08:57 PM. Reason: My SpelL!ng |
12-05-2010, 06:44 PM | #24 |
Ok see thats easy enough,now this same methode will work with just about any pinion you find that you think will work. My buddy Mctwist has used this approach using an alum t-rex 450 pinion though he used the original output shaft with success I suggest you to make a new output shaft like I have discribed. Otherwise,there is very little shaft actually within the pinion. and only 1/2 of that shaft is actualy making contact,as it is flat on both sides. But the output shaft is a snap to make,so no worries there. The hardest part is the pinion,only cuz it is so darn small. But the bolt in the side gives you somthing a little extra to hold onto while your working on it. Also it takes away any risk the threads get bured. Enjoy Last edited by rock hard; 12-06-2010 at 09:11 AM. |
12-05-2010, 06:49 PM | #25 |
Hell yea that looks great. |
12-07-2010, 12:15 AM | #26 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
12-07-2010, 12:21 AM | #27 |
12-07-2010, 12:54 AM | #28 |
12-07-2010, 10:41 AM | #29 |
04-21-2011, 12:11 PM | #30 |
Quarry Creeper Join Date: Sep 2007 Location: mountains of ca
Great idea. Any update if these are gonna be produced? Thanks
04-21-2011, 03:38 PM | #31 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
I love this mod. Since I've gotten used to it, it's become quite a handy feature. It's one of the things that helped me pull off the win at ECC.
04-21-2011, 07:34 PM | #32 | |
Wish I ciould have been there to take part in the carnage. I'm extremely busy at work right now,when things cool down I will be making more of these in batches of 5. | |
05-24-2011, 05:44 PM | #33 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Any word on how McTwists aluminum pinion is holding up? I am also planning on this mod and am thinking about playing with it in aluminum partially as a test drive. Knowing my hand work it is always good to have a spare floating around. edit. Welp. I just made an attempt at this mod tonight between tornado sirens and diving in and out of a closet. It appears I am a little off. Round about the set screw I kept getting a bit of a catch in my giddyup. worked on it a bit but still could not get the issue worked out. I think I got the pinion in a bit of a pickle trying to work it out. Last edited by RickM; 05-24-2011 at 09:45 PM. |
05-24-2011, 09:44 PM | #34 | |
I think Larry runs it also and it has held up for him. | |
05-26-2011, 10:50 AM | #35 |
Getting Garry or Larry to make me one would only prevent me front having a chance to grind off some skin with my dremel!! I noticed your comment about the set screw. I had a perfect one going but the set screw got me turned around. I have purchased the smallest set screws available but I have not been able to try again yet. Here is a question for you. When you talk about the gear mesh spinning cleanly how cleanly are you talking? Does it spin as smoothly as stock or do you expect it to be slightly rougher? |
05-26-2011, 11:13 AM | #36 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
would a 11t bully pinion work?? http://store.rc4wd.com/Bully-11T-Pinion-Gear_p_92.html |
05-26-2011, 05:24 PM | #37 | |
But it should smooth out some as it gets used. | |
05-26-2011, 05:25 PM | #38 | |
05-28-2011, 10:00 PM | #39 |
I got a 12t trex done tonight. I have an extra for good measure as well as a 13t. I worked pretty hard to get the pinion to not be an issue. I also had to shim quite a bit on the diff/ring gear. It is pretty rough but as Paul said that is normal. It was actually supper smooth but I was not getting solid contact, and after getting everything back up and running I noticed it was slipping some. I then went back in and shimmed the diff some more and it ain't slipping but it is rough. I am hoping to get some good break in. I agree that the best material probably steel, but to be honest, after recently tearing up a ring gear I have decided I kindof want the pinion to go first now and hopefully save me the trouble of having to locate a pinion again.
05-28-2011, 10:13 PM | #40 |
