12-26-2010, 08:01 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Santee
| Tech question...
Just picked up brushless MRC in trade...It was working good, but after a couple runs I found I am not getting power from the rear wheels. If I have the rig off the ground they seem to move fine, but when crawling up hill only the front is pulling. I can stop the rear wheels easliy with 1 finger? Any ideas?
12-26-2010, 08:02 PM | #2 |
Probably a broken stock plastic locker. Tear open the axle and check it out...
12-26-2010, 08:07 PM | #3 |
Rock Crawler Join Date: Jan 2009 Location: Great NorthWest
or the center locker (gear box) or the set screws in the driveline |
12-26-2010, 08:09 PM | #4 |
Seems to be in the transmission. I checked the set screw first, I can hold the rear driveshaft with the same result.
12-26-2010, 08:30 PM | #5 |
What a weak design...the rectangle shaped wedge where the metal shafts go into the main gear for the rear shaft is now rounded.
12-26-2010, 08:33 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Without weak designs, there would be no need for aftermarket or replacement parts.......
12-26-2010, 10:32 PM | #7 |
