01-02-2011, 05:10 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: douglasville
| Gear help.
I installed hot racing alloy gears in my transmission ran about 2 batterys through them now they are stripped. Has any else had this trouble with there gears? I am running with a gc3 chassis, mip drive shafts, Novak mongoose motor and esc and 1000 2s lipos.
01-02-2011, 06:15 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
No issues here, I did keep the idle gear plastic and stripped that one out. but the aluminum gears havn't given me any issues
01-02-2011, 06:57 PM | #3 |
I have beat the crap out of alum gears with no worry,I went alum cuz they are lighter. I have put a beating on them also with no issue. Alum will wear fast if its not greased. Did you grease the gears? did you buy them new? |
01-02-2011, 07:47 PM | #4 |
RCC Addict Join Date: May 2009 Location: In the warmth!
Nope, no probs with mine. Ran them all last season. I just checked them and gave a relube the other day. You may want to make sure all your bearings are good. And seated well. Check your tranny case for any deformaties; cracks, etc. |
01-02-2011, 08:48 PM | #5 |
Thanks for the input. It really sux to spend that much money and get such a short time out of it but when. I guess when I get the Money I guess I will try them again, I did like them.
01-05-2011, 09:26 AM | #6 |
One thing you have to becareful of is that whe you put the gears in that you clean all debre in the case. If you strip a plastic gear and dont get the shavings out you could strip out the metal gears.
01-05-2011, 01:46 PM | #7 |
Thanks, Yeah case and bearings where clean of all old debre. I have head mixed reviews on oiling gears I went aganst my better judgmant and did not oil them. I guess IF I try them agian I will try and oil them. Thanks agian for the help.
01-05-2011, 01:59 PM | #8 |
I wouldnt oil them,I would grease them,oil can/will eventually work its way out of the case(leak) and create a mess. Grease will stay put |
