01-15-2011, 08:16 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
| XgerstandtX MRC Re-build
So after completing my LCC MOA and loving that i decided that it was time to jump to the 1.9 class. I posted up wanted adds and everything else looking for a mildly built rig. I ended up getting this rig from el-fernando(thanks man). This rig is really quite nice. \ RCbros skulz chassis Losi alum shocks Alum. skid Alum. knuckles, C's, Lockouts, HB rover 1.9's Proline titus wheels 2 bodies stock electronics China MG servo 150oz servo 2cell 1300 lipo. This was a great looking rig but i noticed some problems to really improve the competitiveness of this truck. As i received it today: TO DO LIST: Upper links too angled, Will lengthen them and make them parellel w/ the ground at ride height No chassis Stand-offs. Creates alot of stress at skid mount Outboard rear shocks Reduce travel of shocks w/ fuel tubing Mirror trans to create more room for batt on upper front links Lower body and make top mounts vs side mounts. Add weight to wheels w/ included titus weights. |
01-16-2011, 06:03 PM | #2 |
Pebble Pounder Join Date: Jan 2009 Location: upstate
You should get the gatekeeper gc3 chassis. I think alot more competitive of a chassis. I saw some on the bay for about 40.00 new.
01-16-2011, 07:44 PM | #3 | |
Changing this chassis is just not in the cards. I am going to tune and run the snot out of this rig w/ minimal financial impact. It's very surprising what you can do with a little tweak here and there. This thing has just ate up all my time in the last 24 hours. I really am digging how it goes together and how it crawls. This is a photo of installing 1/4'' fuel tubing inside the shock body. This reduces the ride height and makes it much more stable. this also helped my upper shock angles. With the way they were it would want to have axle steer when flexing over simple obstacles. Keeping these links horizontal to the ground will do wonders for rigs. The much needed chassis braces removed the pinion spur cover gave it alot more room to install everything Cheap lexan esc/reciever tray mounts. changed up the steering. The stock assembly just created way to much slop and was sacrificing steering angle. Used 8/32'' all thread and Jato rod ends. Very simple and it really helped out the steering Hopefully you guys are diggin it so far. | |
01-16-2011, 07:49 PM | #4 |
a few pictures of this rig on the rocks at our local grounds Deception Pass Park, Oak Harbor WA. My buddies sportsman build running afew lines: |
01-17-2011, 03:51 AM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
Great stuff. A suggestion (you may have already considered): You could flip the transmission 180, easy to do and frees up space at the front upper link. Nice rocks too. |
01-25-2011, 04:51 AM | #6 |
meh.... my build thread is pretty slow. I am still really enjoying this rig. I ran it at it's first comp over the weekend and placed 5th, in our super competitive WARCRC comp. So I was very happy with it and my performance. Before the comp i did a few things, made a rear 4link plate. This completely reduced all the torque twist and made this rig much more manageable. I know it's not super pretty but it beats the piss out of buying one. I also ended up doing a simple caster mod to the front knuckles. This was super simple by just trimming the out side of the axle case to relocate the flats, drill a 1/18'' hole and re-inserting the stock knuckle hardware back in. The front axle also got the treatment of some Losi CVD's. I haven't had any problems with these, but i believe that the LCC knuckle/cvd/c-hub mod will be in the future to add the width to the front. This mod has made my rig way more stable while climbing and turns. It doesn't want to push itself off of the rocks and not push itself over the bead of the tire. A few pics of what the final product came out like. |
01-31-2011, 01:39 AM | #7 |
I am really enjoying this thing still. I burnt up the stock ESC at the last comp. Luckily my buddy ruinx had a spare sidewinder. I shoehorned that thing in there. It is a lot smoother than the stock and the drag brake is second to none(maybe the holmes esc) So after looking around at tons of bodiless chassis' i knew i wanted one. I just couldn't justify the money for them, I'm sure they are great products but my income vs wants just doesn't allow it. It is turning out looking like the Mini juice. I guess that's ok. Mine will be full side plates w/ spacers. This should simlify the process. I will run a little narrower of a skid. Post up what you think I am going to cut this tomorrow. |
01-31-2011, 12:30 PM | #8 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
You got it dialed bud. I'm glad you are liking it AND putting the rig to good use. Enjoy! PS. If i had great crawl spots like you do I would have never sold it! |
02-01-2011, 02:03 AM | #9 | |
Started cutting the plates out: | |
02-01-2011, 02:07 AM | #10 |
This is all done w/ a jigsaw, file, vice and some patience. So don't judge to hard I have been really happy with how this thing is turning out. There are a few lines i would like to be better. This bodiless chassis will be pretty nice. Inputs like usual are welcome, The skid is basic thick cutting board. Will be assembling links and all that as the week goes on. |
02-01-2011, 05:40 AM | #11 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
| Ackerman Mod
If you want to imporve your stearing you can also di this ackerman mod. It will make the front more predictable on tight turns and the front wont feel like it's fighting itself. Also you will get a tighter turning radious than the stock setup. You'll also notice that you can tuck your drag link under the servo and that will get it out of the way of the rocks. AB Design - "M"VP Chassis |
