01-22-2011, 07:09 PM | #1 |
Newbie Join Date: May 2010 Location: Fontana,CA
| losi mrc stock stering servo problem
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } i took my losi mini rock crawler 1/18 to the desert and the stering servo would would get stuck. i could move stering on the remote back and forth and nothing would happen. |
01-22-2011, 07:44 PM | #2 |
does it still have the servo saver on it?? the little spring? You might have stripped out the cheap plastic servo horn. Or do you mean that the servo does not even turn?
01-22-2011, 07:48 PM | #3 |
it will turn then it will get stuck and do mean the spring on the very front of the servo and what is the servo saver
01-22-2011, 08:39 PM | #4 |
Take the servo horn off and try it without it on. does it still get stuck? Do you have the stock transmitter? Yes the servo saver is the little spring thing. It is suppose to help you from not killing the servo. Is this brand new or used?
01-22-2011, 09:07 PM | #5 |
Well I disconnected the steering links and I just had the little white thing and it still got stuck all my electronics are stock but I do have a lipo bat I bot the car new but I have used it befor my transmitter is stock
01-22-2011, 09:13 PM | #6 |
time for a new servo I think. Get some other input from other members.
01-22-2011, 09:25 PM | #7 |
Should I replace the servo with a stock one or a aftermarket one if a aftermarket one witch one would u recamend |
04-18-2012, 08:12 AM | #8 |
Newbie Join Date: Mar 2012 Location: hattiesburg
| Re: losi mrc stock stering servo problem
I am having the same problem it will get stuck but if I has it it will unstick what did u do
04-18-2012, 12:39 PM | #9 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
mine got stuck turning left. i replaced it with hitec 645mg servo but since it is a full size servo and not a mini servo that came stock on the mrc you are also going to need the replace the servo plate too. the stock servo is quiet known for not holding up and one of the first thing to be replaced/upgraded. this is a great place to check out servos that you might think about getting. All RC Servos - Servo Database |
10-12-2012, 07:03 PM | #10 |
Newbie Join Date: Oct 2012 Location: carmichaels
upgrade! stock servos never really last and the stock servos dont have hardly any tourqe in a bind i threw my mini servo out with a full size hs-7954 right away servo savers are junk as well good for the start but never good in the long run
