01-23-2011, 06:54 AM | #1 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Rear axles
So I keep having to replace my rear axle shafts after about every second comp because they bend and clown my wheels. I am using the upgrade Losi stainless ones (LOSB1424). Does anyone know a better solution (other than driving all dainty-like so they don't get bent)? Thanks!
01-23-2011, 07:35 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
I was running into the same problems until I went with what Egressor did in his build. my mrc rebuild It's a bit of work and kinda needs somebody that can do some machining, but it is very solid. |
01-23-2011, 08:20 AM | #3 |
RCC Addict Join Date: Jul 2006 Location: barstow
how about buying the black steel ones that come in the pro
01-23-2011, 08:30 PM | #4 |
RCC Addict Join Date: May 2009 Location: In the warmth!
I used the Losi straight axles for a half hour and they bent. Now I run aluminum lockouts with stock axles. Almost 2 years on 'em, no breakage. |
01-23-2011, 09:10 PM | #5 |
| I was wondering about doing that, all my rigs have been bought used and came with the "upgraded" axles, so I figured there was a reason why none of them had the stock ones. Sounds like going back to stock is a cheap, quick, and easy solution. |
01-23-2011, 09:47 PM | #6 |
| I'm also running stock modified front axles. I got real tired of cvd's breaking for no good reason. I would do the lcc mod & fest knuckles but it's too much $$, have other crawler priorities. |
