01-23-2011, 12:55 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: nunya dambidness
| hot racing product questions
I bought some hr shocks , c's , and knuckles I was Wondering if the knuckles were zero ackerman and also I am having trouble with my shocks not wanting to flex when the front flexes a rear tire raises and won't stay grounded
01-25-2011, 05:12 AM | #2 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
The HR knuckles are not Zero ackerman steering setup. They aren't super hard to shorten the arm and get it close to zero. As for your suspension question it would be best to post picks of your set up. Remember more flex isn't necessarily good. A lower center of gravity rig with less travel will almost always out crawl a super flexy rig. post some pics. |
01-26-2011, 11:06 AM | #3 |
this is what i mean |
01-26-2011, 05:38 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
what springs and shock oil are you running?
01-26-2011, 06:19 PM | #5 |
Pebble Pounder Join Date: Jun 2009 Location: Belle Fourche
hey your not supposed to glue the shocks together |
01-26-2011, 09:19 PM | #6 |
Shannon your an idiot Haha I'm running 30 w |
01-27-2011, 02:38 AM | #7 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
Wow, looks like complete lack of flex!, does your suspension articulate ok if you move it by hand?? If so, I am guessing either; your springs are far too stiff, or there is something binding up and sticking (maybe internal shock part?). Try removing the springs from shocks, then run it and see how the suspsension flexs, see if there are any sticking points. If not, it points back at too stiff a spring. Hope that helps a little. |
01-27-2011, 08:33 AM | #8 |
Ya it moves freely by hand ill take. The springs off and try it
01-27-2011, 08:37 AM | #9 |
Sounds about par for Hot Racing. They make pretty looking stuff that doesnt work well. I'd put them a notch above Integy. Personally, I think the Losi Aluminum shocks with the new cartridges are the best out there for the MRC. |
01-28-2011, 07:43 PM | #10 |
Haha thanks g seems like if I used my head I could have figured it out but now I'm at a crossroads on what to do droop semi droop normal Idk. I have searched around and crawled a few threads but just can't seem to make up my mind
01-29-2011, 02:48 PM | #11 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Do you have any weight in the wheels?
01-29-2011, 04:06 PM | #12 |
ya im running 5 0z give or take a little (dont know what the washers weigh) per wheel and none in the rear. also have a hs5645mg hitec servo
01-31-2011, 07:42 AM | #13 |
Anyone have any suggestions towards suspension setups regarding comping I just can't make up my mind what to try next. I have checked threads here and there but can't come up with a good solution. I am open to all suggestions send me a pm ( if you want to be secretive haha) or post here. I NEED HELP!!!
01-31-2011, 03:17 PM | #14 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
01-31-2011, 03:28 PM | #15 |
also consider swapping out the blue springs in the rear for the stock silver, they are softer. |
