01-31-2011, 08:18 AM | #1 |
Newbie Join Date: Dec 2010 Location: South Jersey
| Slingshot Build
Just starting to get into crawling after playing with my brothers MRC so i decided to get one of my own, found one on Ebay and scooped it up it had a sling shot chassis, losi threaded shocks, and a hobbico servo this is what i got First thing i did was wheels and tires, 1.9 FlatIrons on 8 spoke Aluminum Beadlocks weighing 4.3 ounces a piece so no need to weight them...yet Next came a Holmes Hobbies 33t motor, Tekin B1R ESC, Hitech HS-645MG servo, Losi Metal Lockers all around and Tranny flip I have lipo's on the way, 2s 850Mah and cant wait till all this snow melts so i can go out and Bash this thing!!! |
01-31-2011, 10:15 AM | #2 |
nice find,that chassis has worked very well for me in the past. I will say that 4" tires work best IMO with that chassis. |
01-31-2011, 05:52 PM | #3 |
Rock Hard do you remember what shock set up (brand & oil weight)
01-31-2011, 06:48 PM | #4 |
15 wt oil all the way around,but I ran my shocks inside the chassis look for some pics in my "sling shot retired" thread. Its here somewhere. |
02-01-2011, 10:47 AM | #5 |
Having an issue with my motor, it seems like it has a dead spot, it will not turn when i pull the trigger but if you turn the spur gear a tiny bit if works fine anyone have any ideas for me?
02-01-2011, 12:05 PM | #6 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Pull the motor and try it without any pressure on it. If it is stock ditch it and buy a motor from Rockhard. I am saving my quarters from one myself.
02-01-2011, 07:30 PM | #7 |
Looks to me like it has a quality motor already.... its probably iether a holmes,or a trinity mini moster its got the cobalt blue can though..... do like rich suggested,remove the motor pinion and see what it does. It could be a # of things though.It may be a stuck brush could be the brushes are worn could be it needs a cleaning could be a combination of all. I myself would deffinatly remove the motor and open it up,and give her a good inspection/cleaning |
02-05-2011, 10:57 AM | #8 |
I'm running a HH 33t and it only has about an hour of run time on so the brushes shouldn't be worn yet but I will pull the motor and check averything, thanks guys ill post my results when I get to it
02-06-2011, 08:11 PM | #9 |
turned out to be a stuck brush thanks for the tips guys i'm new to this haha |
