02-14-2011, 10:09 PM | #1 |
Rock Stacker Join Date: Oct 2010 Location: Keller
| What shock oil are you running?
Interested in what others are using in shock oil weight or even what oil combo. I read many threads on oil just want to see what others are running and any advice and tips would be welcome.
02-15-2011, 08:27 AM | #2 |
Losi Aluminum Shocks, 25 wt oil, Mini-T springs (pinks in the front, red in the pass rear, orange in the driver rear).
02-15-2011, 11:47 AM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: moses lake wa
That depends on what chassis and weight ur running? Try to find a set up that Matches what your running and give that set up a try Then change from that. I'm running 35wt oil in all my shocks and 3 hole pistons in front with soft mini-T front springs and 2 hole on left side of the rear with silver mrc stock spring and 1 hole on the right rear with a losi pro stock blue spring. My chassis as a pro with rear lower links in the upper holes. Also my tranny is setting with the motor facing front. The set up I'm running works great for me. Hope this helps |
