02-22-2011, 08:25 AM | #1 |
Rock Stacker Join Date: Jan 2011 Location: wisconsin
| Zero Ackerman Steering w/ GC3 Chassis?
I'm new to crawling and recently bought a MRC and upgraded it w/ a GC3 chassis, losi alum bead locks, losi threaded shocks (w/ outboard mount) as well as a full size hitec servo but have some questions on other mods I am thinking about. 1. I want to increase the steering range so from reading I see I need CVD's and looks like the Losi ones are working well. My question is will this work with the GC3 given that my losi shocks have been outbarded or will the shock springs prevent the tires from turning too much further. If this can be done then are the CVD's all I need or do I need to buy zero ackerman knuckles and other parts too? 2. Is there a servo tray for the GC3 that can fit both the FS servo and lipo like in the MRC Pro or would I be better off doing something different? Thanks for the help! |
02-22-2011, 10:53 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Most GC3 users are running CVD's and Zero Ackerman knuckles. The outboarding of your shocks can possibly interfere slightly with your tires depeding on which you are running. However, you should be fine with this as well. You can also limit the steering with your radio before the tires make contact. Running a full size servo and a lipo up front can be done, but its a very tight fit. |
02-22-2011, 11:18 PM | #3 |
If you use wheel wideners then I doubt you would have any issue with the shocks/tires rubbing.If so it would be minimal. Alot of guys run thier battery ontop oof the fron upper links,behind the servo. |
02-23-2011, 09:25 AM | #4 |
Thanks guys but still confused and I want to try to order all I need at the same time to save on shipping. So to get more steering I need to order the CVD's, knuckles and possibly wheel wideners? Or will just CVD's do it? By wheel wideners are you talking about wider wheel hexes like from the MRC Pro or something else? Guess I'll have to find a different mounting option for my lipo. Will look at pictures to get some ideas. |
02-23-2011, 09:26 AM | #5 |
Yes I've seen them on top of the upper links but I can't fit the lipos I have in there without them obstructing the movement of the links. What size lipos work well there? Thanks! |
02-23-2011, 07:27 PM | #6 | |
There are many types of wheel wideners, however the MRC pro wider wheel hexes are what most run. | |
02-24-2011, 05:28 PM | #7 |
Ok so got the Losi CVDs installed & no rubbing at all w/ the shock springs. Now I'm looking of adding those zero ackerman knuckles but not sure if that's going to require I change up the steering links for them to work right?
02-25-2011, 09:31 AM | #8 |
RCC Addict Join Date: Jan 2009 Location: Bend
Yes, running the zero Ackerman knuckles will require different steering links. if you're gonna go as far as buying knuckles and steering links, finding or building a drag link thats the right length to mount to your servo setup, and all that you may as well do this: Knuckles- http://cart.rcbros.com/product_info....knuckles-p-265 Tie Rod- http://cart.rcbros.com/product_info....eer-link-p-266 4-link/servo plate- http://cart.rcbros.com/product_info....nk-mount-p-179 |
02-25-2011, 11:55 AM | #9 | |
Yeah I looked at that but I don't think/know if it works w/ a GC3 chassis which already has it's own 4 link. Thanks though! Quote:
02-25-2011, 12:16 PM | #10 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
I've been running Traxxas Wide hexes on mine with good results.
02-25-2011, 07:49 PM | #11 |
02-26-2011, 01:44 PM | #12 |
Rock Stacker Join Date: Feb 2004 Location: Western WA
On mine I am running the Losi CVDs, Losi wide hexes, and zero Ackerman knuckles from the MRC Pro. Works great. With outboarded shocks and Losi beadlocks my tires do rub a bit on the springs when one corner is stuffed but it's not too bad. For a tie rod I'm just using a 3mm turnbuckle, I believe about 95mm in length, along w/ Axial offset rod ends. My drag link is a long 3mm screw cut to length. BTA steering would be nice but there's no way it'd fit w/ the GC3 suspension links and my low ride height. I'm running a Max Amps 2S 800mAh lipo on my upper links. It's a tight fit. - Chris |
02-26-2011, 03:29 PM | #13 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
sorry for asking a dumb question, but how much more do the Zero Ackerman knuckles give you?
02-26-2011, 03:53 PM | #14 | |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
At stock, the tyres scrub when turning. Zero ackerman has the tyres turning at the same amount, so they tend to work together more. There is better literature on the net to explain ackerman. Ideally we would run true ackerman to have the inner wheel turn more than the outer. Then both wheels follow their individual turning circles (outer wheel follows a larger turning circle, so does not need to turn as tight as the inner wheel, and vice-versa) in a nutshell: zero ackerman will give a smaller turning circle due to reduced scrubbing. | |
02-26-2011, 03:56 PM | #15 | |
or am i not getting your answer? | |
02-26-2011, 07:09 PM | #16 |
So if I already have the Losi CVD installed does adding the Zero Ack knuckles make enough of an improvement? If so what I would do is get the losi zero ackerman knuckles & drag/steering linkages from the MRC pro. |
02-26-2011, 07:23 PM | #17 |
Rock Crawler Join Date: Jun 2009 Location: Middleburg
| IMO yes they make that much of a difference. All I run zero Ackerman on all my trucks.
02-26-2011, 07:25 PM | #18 | |
It doesn't increase the throw of the steering, it increases the amount of scrub on the inside turning tire (which is a sharper angle) which then in turn reduces the area needed to turn. (smaller circle) | |
02-27-2011, 09:52 AM | #19 |
Ok did some reading on the concept of ackerman steering & makes sense so i will be ordering the MRC Pro zero ack knuckles along with the MRC Pro steering links & wider hexes and give this a shot. Thanks for the help!
02-27-2011, 10:49 AM | #20 |
Don't forget about our High steer knuckles.
