02-23-2011, 09:51 AM | #1 |
Rock Stacker Join Date: Jul 2010 Location: Tampa
| Wheel Wideners
Are there options for wheel wideners for the MRC or is there only one extended size, if you run some can you link me to the kind you run please. I just ordered literally ordered everything for my crawler and I plan on running the 4.7 boggers some I'm thinking wideners are in order……Thanks again for all the help guys I appreciate the tight knit MRC group we have.....and ill make sure I put that in my build thread
02-23-2011, 10:13 AM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: here
Those tires are going to be huge on the MRC. I git some wideners from TCS and they work good. I've also seen someone cut down the widener and make a new pin mount so that they weren't so wide.
02-23-2011, 10:19 AM | #3 |
I know they are 4.7s but I'm running the snipe dmg chassis and factory size lowers and I have a nice trick up my sleeve for link placement that should clear them....but I still want a nice track width
03-09-2011, 08:37 AM | #4 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
I may have a set of mrc wideners I could sell.
05-03-2011, 08:24 PM | #5 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
| http://www.tcscrawlers.com/2.2-Wheel...g-p-16233.html You may need to drill the center hole in your wheels slightly larger to accommodate the long & extra wide nut. Some of my wheels I had to drill & some were fine. I run the widners only in thr front so my rear tires have less chance of clipping a gate. |
05-05-2011, 08:14 PM | #6 | |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
What about these http://www.junfac.com/shop/index.php...7e0e9c950d02b7 They are 11mm and a 12mm hex. Made for a smaller car.? | |
10-02-2011, 12:36 PM | #7 | |
Newbie Join Date: Sep 2011 Location: Ontario, Canada
10-02-2011, 03:41 PM | #8 |
Rock Stacker Join Date: Jun 2011 Location: Red stick
10-05-2011, 12:23 AM | #9 |
Newbie Join Date: Aug 2011 Location: 425
Has anyone had problems with premature bearing wear, or more broken knuckles? It's a problem on 1:1 cars, and it seems alot of stuff scales down.. especially the price, lolsz
