02-28-2011, 02:54 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
| Weight thread
lookin to make a thread on total weight and front/rear tires. Post up what your running |
02-28-2011, 03:47 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: moses lake wa
9.8 front 5.5 rear per tire
02-28-2011, 07:19 PM | #3 |
Newbie Join Date: Apr 2008 Location: Colorado Springs
02-28-2011, 07:54 PM | #4 |
Rock Stacker Join Date: Jan 2011 Location: Washington
Who needs weights when you have chisels? |
02-28-2011, 08:13 PM | #5 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
8oz front, 0 rear. found that its a good set up for me.. Last edited by MRCCRAWLER1.9; 02-28-2011 at 11:44 PM. |
02-28-2011, 10:41 PM | #6 |
| No it's contraband 18 turn motor and fxr and 3s Lol that's per tire too lol by the way Last edited by baddman; 02-28-2011 at 10:45 PM. |
02-28-2011, 11:14 PM | #7 |
| And I thought I was pushing the envelope with 7oz in each tire up front. Im still using my original esc and motor. I have to break it to either fix it or upgrade. ESC and motor will definitely be my next upgrade.
02-28-2011, 11:44 PM | #8 | |
my stock setup wouldnt even hold 2oz in front.. | |
04-29-2011, 02:28 PM | #9 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
I'm trying to get weight dialed in for comping... I'm not sure where you guys are even fitting 7oz+ in each wheel. Is a lot of that weight just from aluminum wheels? I have the stock wheels and did the beadlock conversion and was able to fit only 1.5oz in per wheel (above the stock wheel/tire weight) my body torque is still a weak point and I'm thinking more weight up front will really help. Am I going to have to get new wheels for the added weight?
04-29-2011, 05:09 PM | #10 |
well, there is space in the inside of the wheel that faces towards the axle, which acts kind of like a knuckle weight. most people will use Lead weights for that, since it weights alot. |
04-30-2011, 01:22 AM | #11 | |
Newbie Join Date: Apr 2011 Location: Ohio
04-30-2011, 02:12 AM | #12 | ||
Thanks, for some reason when I first looked at doing that I thought that the knuckle would get in the way so I didn't take a second look. But I went ahead and did it tonight and was able to get an extra 1.5 oz per front wheel. Quote:
04-30-2011, 04:03 AM | #13 |
Newbie Join Date: Aug 2007 Location: England, Yorkshire, West yorkshire, Leeds
I can't remember exactly, but box stock elecs, box stock wheels I'm running home made lead weight at about 3 oz front and 1 oz rear (per wheel). I think I need to invest in some ally wheels 9 oz in each wheel??? |
05-01-2011, 03:52 PM | #14 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
Between all my sets (stock, flat irons, chisels & red rovers) my average per tire+wheel+weights is: Front: 7.5oz per side Rear: 4.8oz per side |
05-01-2011, 03:57 PM | #15 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
8 3/4 oz. in front 2 oz. rear plus i have the losi beadlocks
05-01-2011, 05:24 PM | #16 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Guys in NTX are starting to get the trucks in the air some. Been working to get my center of gravity as low as possible and run as little as possible at the corners. Right now I have one ounce in each BWD aluminum front wheel, with knuckle weights. I am also running and ounce in the rears on the axles and running Delrin BWD wheels stock.
05-02-2011, 11:15 AM | #17 |
Pebble Pounder Join Date: Oct 2010 Location: In the dog house
Not sure exactly, will weight them later, how much actuall weight I am running, but I used solder wrapped around the inside of the wheel instead of stick on weights. No way to loose the weight this way. Here is an example; it is one of my AX-10 wheels, but it is done the same way as the mini wheels. |
05-02-2011, 12:01 PM | #18 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
pretty sure im runnin 4oz per front tire, none in the rear, not sure of total weight. If i remember ill throw the stuff on scale tonight |
05-02-2011, 04:26 PM | #19 |
Newbie Join Date: Oct 2010 Location: Omaha
We just had Jay Robinette here for the Central States Challenge in Omaha. He's running aluminum wheels all around with the Losi MRC wheel weights in front with an ounce of weight on the front axle. No extra weight in the rear. That put him around 3.5 ounces for the rear wheels and 5.25 ounces in the front.
05-02-2011, 08:28 PM | #20 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
running 3 1/2 in front nothing in the rear
