03-14-2011, 08:46 PM | #1 |
Newbie Join Date: May 2010 Location: Fontana,CA
| Beedlock Need help
I am looking for a set of real beed locks? |
03-15-2011, 02:05 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
check out the vendor section, for sale section and check out rpphobbby.com, rcwd.com, vanquishproducts.com you get the idea.
03-17-2011, 04:00 AM | #3 |
Quarry Creeper Join Date: Apr 2009 Location: Hampshire, UK
As CrawlHer says, look in the vendors section, there are loads to choose from and a lot will depend on your budget. A few things to consider - aluminium, delrin or plastic? Think about whether you want to run weighted or unweighted. Some offer add on weight systems (Losi, Pro-Line and Axial) others you can add self adhesive lead weights to the inside of the rim or add weight to the knuckles as per Rockhard and Erik D Lux Knuckle weight mod Dlux mini build Then the width of the wheel - a narrower wheel gives a more rounded profile to the tire and increases the diameter. A lot will depend on the tire you run. Hope this helps. |
