03-23-2011, 09:47 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
| axle gears strip alot
i have to shim my rear axle alot we have monthly comps n we have mini comps once or twice a week. b4 the main comp i have to shim or replace the gears. i run the tsl swampers so i know the tires r biggr n have binding issues in the rocks but is there a way to strenghten the housings or better gears out there any ideas anyone? n rite now its mostly indoor comps so holes r common
03-23-2011, 10:05 AM | #2 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
Have you done the axle bolt mod? Replace the four 2mm screws around the diff with longer bolts and add a hex nut to sinch the axle together.
03-23-2011, 10:10 AM | #3 |
guess thats what i get to do today then thanks
04-12-2011, 08:36 PM | #4 |
this workd to help them servive
04-14-2011, 08:41 AM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
Another thing that I did was shim the diffs to remove the side to side play.
04-16-2011, 10:20 AM | #6 |
Newbie Join Date: Feb 2011 Location: Nederland,Colorado
I got metal diffs for mine
04-17-2011, 11:17 AM | #7 |
the bolt mod is working good i havnt had to reshim 4 a couple weeks now finally haha have you guys tried the underdrive im really thinkn i need to try it rockhard how long does ur rear diff last now?
