03-23-2011, 10:21 PM | #1 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
| Axle Link mounts breaking. please help.
Well guys, ive noticed that on my mini, that 1 big issue i have is that the axle Shock and lower link mounts always tend to break off too easy, is there any way to make them more durable? i think losi should also thicken the plastic alittle, i feel that it is just too thin at times. |
03-23-2011, 10:33 PM | #2 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
Don't over tighten! I've been compin' my same housings for 2 years w/ no problems...
03-23-2011, 10:36 PM | #3 |
Wow, thats incredible. does the screw hold though? im worried of the screw loosening out easy. |
03-24-2011, 08:05 AM | #4 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I also broke the thin side of the mount trying to mount my shocks outside the mount position. They are not the strongest by any means. I suggest having some spares around as well. I do agree that over tightening things might be a culprit simply because the rod ball ends are pretty sharp and small. One thing I might suggest after looking at your build pics is it looks like something is either stressing or binding the link/shock mount and causing it to bend a bit on an angle. That might be something to take a look at in my opinion. |
03-24-2011, 08:19 AM | #5 |
Pebble Pounder Join Date: Jun 2010 Location: Clever
I have been running my rig for a year on the same housing. My son tightened his shock mount down just a little to tight, you could see it was slightly bent in and the outside snapped after the second pack.
03-24-2011, 08:36 AM | #6 | |
Also, you maybe right, as I run the mini gc3 and man, do those links need some pressure to place it into position. | |
03-24-2011, 09:34 AM | #7 |
Are you outboarding them? If so, are you using a proper sized spacer between the mounts?
03-24-2011, 10:01 AM | #8 |
03-24-2011, 10:16 AM | #9 |
I also have them outboarded w/ a spacer. If yer worried about them backing out just add a dab of BLUE locktight and yer golden! And I had to sand the shit out of my skid on the GC3 to get the links to move freely...
03-24-2011, 10:48 AM | #10 |
Ah yes, I will be using blue lock tite. btw. do you know that traxxas rod that uses the e clip that people use to hold the lowers in place for the gc3? if so what is the part number? |
