04-21-2011, 12:32 PM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: MN
| MRC shock question/clarify
Ok, in the sticky guide above it says to disassemble the shocks and install tubing on the inside shaft. So if I am thinking right doing this will shorten the shaft/shock and lower the chassis? And if so could you get the same effect by using a limiter strap of some kind to pull/compress the shock from the outside?
04-22-2011, 09:15 AM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
try the fuel tubing on the outside shaft just to limit the travel try different sizes to fit ur likn helps to make truck more predictable
04-22-2011, 09:45 AM | #3 | |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
By only adding the fuel tubing outside the shock body, you only change the effective compression length of the shock and limit articulation. By placing a spacer underneath the piston on the shock shaft, you limit the rebound length and effectively lower GC/ride height. With this done at all 4 shocks you will limit articulation as well. Two birds, one stone | |
04-22-2011, 10:17 AM | #4 |
Thanks for the input! Both good points and the what I was looking for I'll probably disassemble and put the tubing on the inside. I'm thinking it will require less oil as the tube takes up space. I ordered a GC3 chassis so I hope to post a build thread! thanks |
04-22-2011, 01:11 PM | #5 |
Newbie Join Date: Feb 2011 Location: Nederland,Colorado
I took my shock apart and put pin springs in side of the piston and it helps a lot
