04-22-2011, 10:02 PM | #1 |
Newbie Join Date: Feb 2011 Location: Santee EC SD!!!
| VID added clocked Mod on Zero Ackerman High Steer Knuckles with OTA ok i have installed a High Steer Link & Zero Ackerman High Steer Knuckles (over the axle sterring) from RcBros They look and work like a champ!! hats off!! clears alot of hang up in the front. my question is I want to clock my knuckles but kinda worried about the clearance over the axle with the linkage? has any one done this mod with this setup? how far did you go? any issues? Thx Doug http://www.youtube.com/watch?v=g1c_vu6pmVI Last edited by Dougie67; 04-25-2011 at 09:46 PM. |
04-22-2011, 10:12 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Doug, The mod is pretty easy with a dremel, simply flatten the edges and turn the c's, drill new holes and your done. The only issue I've found is if you don't go far enough, you'll break back into the factory holes. I am working on adjustable aluminum clocked c's and should have them done soon. This makes it a bolt on mod. |
04-22-2011, 10:49 PM | #3 |
ok thanks for the fast reply ill give it a shot |
04-23-2011, 07:51 AM | #4 |
RCC Addict Join Date: May 2009 Location: In the warmth!
04-23-2011, 11:46 AM | #5 |
Hey ya there you go pic helps alot thanks!
04-25-2011, 09:25 PM | #6 |
| heres a vid well its almost done got to fab a link from the servo to the knuckels. had to make a little room for the ota link to clear. filed some off the back top of the pumkin, turned out pretty good still retained my steering radius with the CV joints check the vid out!!!! http://www.youtube.com/watch?v=g1c_vu6pmVI |
05-02-2011, 09:38 PM | #7 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
here is my steering, all I have are cvt's and bling parts. Nothing special and I get so much steering while driving it rubs all over my 4 links. I have it turned down alot http://www.youtube.com/watch?v=y-5GTvHe2l8 so with all your setup what does it do exactly, mine is basically stock setup with 2 aftermarket parts pics yours and mine Last edited by mikegigabyte; 05-02-2011 at 09:43 PM. |
05-02-2011, 10:56 PM | #8 | |
If you look mine is clocked a bit. 20 deg. (better side hilling) There is no drag/steering linkage in front of the axle (nothing to get hung up on) alot cleaner look i think. Quote:
05-02-2011, 11:15 PM | #9 |
I can agree with the linkage catching, but looks like it still has them in the way, from the angle I see but the steering is so reduced, especially with using cvd's needs more throw |
