06-28-2011, 07:04 PM | #41 |
I was running a 10t pinion and the motor was quite HOT.
06-28-2011, 09:58 PM | #42 |
07-01-2011, 07:28 AM | #43 |
This motor is great! It is super smooth at a crawl but it can get up and GO. Now I just have to get used to it because I've been running a 18.5 Mongoose since day 1. Thanks Paul! Jslick, I ran for a few minutes this morning and I didn't notice any abnormal heat issues. I will get some more time in this weekend and I will post up if I have any issues. setup: 17t contraband w/12t pinion Sidewinder Micro Castle BEC powering the servo only Turnigy 500mAh 2s 20c |
07-02-2011, 01:45 AM | #44 | |
07-02-2011, 01:51 AM | #45 |
| Some people do seem to run hotter.There is a guy in our local club and his runs a touch hotter than mine. Could be a little to do with drivetrain,maybe weight,or driving style even,or maybe a little of everything. with a 10t pinion you may be needing to much throttle to get your speed. get a 12t pinion with the 60t spur and see what you get,thats the set up you want IMO. |
07-05-2011, 03:53 PM | #46 |
thanks for the help. |
07-05-2011, 03:54 PM | #47 |
After a few packs mine for sure runs hot. It even warms up my lipo and that can't be good. I'd like to try a lipo with a higher C rating to see if that helps.
07-05-2011, 07:29 PM | #48 |
did some more work on it. Ran the 12t pinion but it looks like my 45c 325mAh 2s will not cut it, I only get about 3-4 min out of them. My 800mAh 2s work well, the lipos are getting hot and I puffed one of my older ones. Not sure what direction I want to go. I love the motor, just need to find a good battery and a way to keep it cooler.
07-09-2011, 12:28 AM | #49 | |
Back to back packs will do that,I dont know if your allowing for a cool down between packs or not,in the summer heat it will be even worse. A higher c rating may help,the thunder power 45c 90c burst are what I run and love em. | |
07-09-2011, 12:29 AM | #50 | |
Pm sent,you should get more than 3-4 min,hell thats not enough to finish a course. | |
07-09-2011, 05:19 AM | #51 |
PM returned, thanks. |
