07-22-2011, 10:51 AM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Trafalgar
| MRC PRO Slipper????
Hi, wen i get in a bind with my mrc is starts clicking...stripped gears or slipper? Wat happens is if the front end gets in a bind the front end stops and the rear still spins all while its clicking..
07-22-2011, 11:28 AM | #2 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
Sounds like a front locker to me. But I will let someone else chime in that has broke theirs before. |
07-22-2011, 01:21 PM | #3 |
Rock Stacker Join Date: Dec 2009 Location: maine
Try to put the truck into that situation, where the rear tires spin and the fronts don't, while the body is off. Watch your gears, start at the motor. If both sides of the slipper are moving, it's not your slipper. Further down the drivetrain, look at the center diff/gear, are both output shafts off the transmission/that gear spinning, if they are, it's not your center locker/gear. Finally, are both your front tires not spinning, or just one? If its just one spinning, its your front locker/center gear.
07-23-2011, 09:32 AM | #4 |
Well i checked my front lockers...good..now down to center diff and spur rite?
