07-14-2011, 09:44 PM | #21 |
Rock Stacker Join Date: May 2011 Location: Istanbul
Well, it's me again. My MRC Pro build finally reached to an end. As I said on my earlier posts, I'm temporarily using the stock RTR MRC servo but I don't think it's going to survive a month. I tried some tricky lines at the garden and after only 2 minutes, yes 2 minutes, servo was operating at 199F. That kinda temperature can't be healthy for the servo I assume. Anyway, can't wait to grab that Savox. I made an electronic tray from a DVD cover, mounted my receiver on the top and ESC behind the transmission box, right above the drive shaft. Secured it with both plastic wraps and double-sided sticky tape. It turned out pretty solid and most of the weight is towards the front. Here is the tray, macro. I used foam cable clips and they are pretty awesome if you ask me, it's easy to route the cables and secure them but when they got pulled, foam lets go before the cable binding occurs. I bought a plastic velcro to secure the battery on the side of the chassis. This thing is stronger than a regular cloth velcro if the sized are the same and also, it doesn't lose grip no matter how many times you pull it apart. Holds the battery pretty well and removing is easy. My 800 mah 2S 7.4V lipo, 10C rating; meh... Wrapped electric tape around it so the velcro can hold it better. Double sided tape don't like slippery, shiny heatshrink. Now onto the paintjob. This was my very first paint job but outcome was self-satisfactory. I quite like it to be honest. I made some paint masks from a vinyl and slapped em on her then sprayed white, when it's over I carefully removed the masks and went in with the black. It was easy, not messy as I expected at all and that Tamiya lexan paints (in little cans) smell pretty good and makes you feel oooooooh-kay. And a couple of naked shots with the battery attached. That's it. Also here is a video of her maiden voyage. It's just a couch crawl, nothing impressive at all but I wanted to try it ASAP! I attached the camera to the transmitter with a piece of tape so camera work is a little off, sorry for that. http://www.youtube.com/watch?v=IxRab...yer_detailpage I really like the Novak Mongoose system so far. I haven't done any serious crawling but torque, speed and smoothness is very enjoyable. I'm using the 2nd profile, Expo and boosted the drag brakes to the max. It still lets go a little on hill but very slowly and a little bit of finger movement can set her still. I don't mind this at all and was aware of it before buying it. I'm using the included Titus rim weights in the front, nada on the rear wheels. I'll fine tune the chassis and weight once I get my servo and drive her a little. If you got something to ask, fire away. Thank you for reading. Boney's out, Peace. |
07-16-2011, 05:50 AM | #22 |
Took her out today and these are the results. I found a new spot to crawl, lots of white, somewhat soft rocks. I don't know the kind but they're very dusty and every time my skid plate hits em when I'm trying to hop it up, they brake a little. I couldn't resist the urge and went all in. Let me tell you that "heat" is definitely not a problem for that stock RTR servo. Before it got even warm, I destroyed the gears inside. Now I have no steering at all and got to wait for a month for a new servo, LOL. I'm seriously consdiering using my Savage's servo on this lil bugger but I just can't think a month without a Savage. Anyways, I need to stiffen the front end, too much articulation and needs heavier oil. Weight ratio is pretty nice but I can add some to the front, maybe... I need to lower my body a little so it's easier to get her off of her back onto the wheels, though she still manages to get back up. I really liked that spot, got to take a video of her crawling with a new servo right there. P.S. Dogs hate the sound of a servo with stripped gears. They can't stand it at all. Also do not forget your transmitter on the roof of your car. It comes down from the windshield on to the hood on your first brake and scare the ****ing crap out of you. I was this '' close to scream like a little girl but too high to find the energy to do it... No, transmitter is not broken, just some scuffs and couple of seconds to waste while looking for the batteries. |
07-16-2011, 07:25 PM | #23 |
Newbie Join Date: Jul 2011 Location: Lucedale
| Rob33
Pick up some bent links for rear suspention. Weight for wheels more in front, my bro and I used solder wire not elec solder got to lowes homedepo and get plumbers solder. also wheel wideners for front whop and i shared to cost because $34.00 for 4 and 2 will do. Hope this helps!!
07-16-2011, 07:31 PM | #24 |
| Rob33
Get a Hi Tec 645MG servo some say its to big but it works well on down side only 2 screws hold to mounting plate not going to break though!! I found a new spot to crawl, lots of white, somewhat soft rocks. I don't know the kind but they're very dusty and every time my skid plate hits em when I'm trying to hop it up, they brake a little. I couldn't resist the urge and went all in. Let me tell you that "heat" is definitely not a problem for that stock RTR servo. Before it got even warm, I destroyed the gears inside. Now I have no steering at all and got to wait for a month for a new servo, LOL. I'm seriously consdiering using my Savage's servo on this lil bugger but I just can't think a month without a Savage. Anyways, I need to stiffen the front end, too much articulation and needs heavier oil. Weight ratio is pretty nice but I can add some to the front, maybe... I need to lower my body a little so it's easier to get her off of her back onto the wheels, though she still manages to get back up. I really liked that spot, got to take a video of her crawling with a new servo right there. P.S. Dogs hate the sound of a servo with stripped gears. They can't stand it at all. Also do not forget your transmitter on the roof of your car. It comes down from the windshield on to the hood on your first brake and scare the ****ing crap out of you. I was this '' close to scream like a little girl but too high to find the energy to do it... No, transmitter is not broken, just some scuffs and couple of seconds to waste while looking for the batteries.[/QUOTE] |
07-16-2011, 08:34 PM | #25 | |
Quarry Creeper Join Date: May 2011 Location: USA
And I ask because I don't really know how the servo measurements go. I just got the MrCPro and I've been trying to figure all this out and getting a servo is on my list of things and I'm trying to figure out how they do the measurements... | |
07-16-2011, 10:50 PM | #26 |
Yes that servo will fit on the MRC Pro. You can just move the servo mount over to the next hole....
07-17-2011, 11:05 AM | #27 |
07-17-2011, 04:36 PM | #28 | |
Bent links are on my "to do" list. I already got weights inside the front wheels. Also could you please post a link for the wheel wideners? I can't find the one for MRC Pro. I would seriously love to widen the front a little. | |
07-17-2011, 05:00 PM | #29 |
Quarry Creeper Join Date: Nov 2010 Location: Atlantic
07-17-2011, 05:11 PM | #30 |
Is that a direct fit to MRC? It says 2.2 wheels on the site.
07-17-2011, 05:31 PM | #31 |
they are 12mm hex so they will work with the mini or 2.2.
07-17-2011, 05:36 PM | #32 |
Thank you very much brother! Added those to my list! |
