06-15-2011, 12:48 PM | #1 |
Newbie Join Date: Aug 2005 Location: B'ham
| budget MRC pro roller build - Newbie needing help!
So I just bought an MRC pro roller from Ultimate Hobbies for cheap, and now I have to add electronics. I've got an AX10 I've been modding and messing with for a while but I bought it RTR so I'm lost when it comes to electronics. I need: Radio/receiver ESC battery (lipo) (already have charger) motor servo The plan for this thing is a reliable, easy to use crawler for my girlfriend. Don't need anything super fancy, so I'm trying to do this on a budget. I'm also trying to build around a scale body off my Nylint Jeep from back in the day. I need suggestions on parts. I'd like to spend less than $200 total if possible. Thanks! |
06-15-2011, 01:12 PM | #2 |
You want brushed or brushless? Batteries, CBP has a 350mah 2S for ~$15 shipped, we have 6 of them (3 for each MRC rig). Radio, if you like your existing one, get another RX and be done. |
06-15-2011, 01:16 PM | #3 | |
One option though is if you are thinking of upgrading your own radio, now is the time to do it and set your current radio up for the MRC. | |
06-15-2011, 03:29 PM | #4 |
06-15-2011, 03:30 PM | #5 |
| That would be a good idea, but I got a 3 channel with mine already that I'm happy with. Just need to get a cheap set up for the mrc.
06-15-2011, 04:35 PM | #6 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
here is what I did because I was going for the cheap setup also: Servo: Hitec HS 645MG $27 http://www3.towerhobbies.com/cgi-bin...&I=LXUZ89&P=ML ESC: Tekkin B1R $58 http://www3.towerhobbies.com/cgi-bin...?&I=LXNZW3&P=7 Raido / Receiver: Flysky FS-GT3B rx/tx combo: $35 http://www.hobbypartz.com/79p-gt3b-carradio-lcd.html Motor: Stock Losi MRC motor $10.00 http://cgi.ebay.com/LOSI-LOSB0839-MO...#ht_2614wt_905 Lipos: Bluesky 800mAh 20c 2s $6 x2 or more... http://www.hobbypartz.com/83p-800mah-2s1p-74-20c.html Local hobby shop: Aluminum servo horn $6.00 Deans plugs all around $10-$15 A few strips of stick on lead weights $10 That should get you up and running nicely |
06-15-2011, 06:13 PM | #7 | |
RCC Addict Join Date: May 2008 Location: Justice world headquarters
Thanks for the info | |
06-15-2011, 07:06 PM | #8 |
heck from that list the only thing you need to upgrade is the motor! my running gear is very close to that and ive got around $240 in mine |
06-15-2011, 10:23 PM | #9 |
Not a bad list at all! What kind of run time should I expect with an 800mah 2c? I know I'm going to be VERY limited on space but I do want a good amount of run time. |
06-15-2011, 10:55 PM | #10 |
I've only ever known a Rooster Crawler on my ax10. How would the Tekkin B1R compare? Will the brake lock up the tires? First to reverse?
06-16-2011, 01:42 AM | #11 | ||
Straight solo crawling I get 45-50 min on a single battery. I bought 4 initially and i think I should have just bought 3. The size is perfect for setting it on the front upper links also. Quote:
I think I understand the question about the brakes locking up the tires. The Tekkin B1R has several reverse modes. It took me a little bit of reading and re-reading the instructions however you can switch the foreward - to - reverse transition. If you use the 2nd of the 3 options it will behave the way you want it to where it locks up instantly upon releasing the throttle. And will go instantly into reverse without a brake delay... I hope that helps Last edited by Getrag; 06-16-2011 at 10:11 PM. | ||
06-16-2011, 07:25 AM | #12 | |
06-16-2011, 11:07 AM | #13 |
Yes you will need to solder. It also comes with a capacitor and doesn't mention what to do with it. you will want to solder the long wire coming off of the capacitor to the battery + post on the esc, and you will want to solder the other wire on the capacitor to the battery - post on the esc (you will also have to solder wires going to connectors on the same posts, this connector will be what you plug your battery in to.) Sorry I don't have my crawler with me otherwise I would take a pic |
06-16-2011, 05:40 PM | #14 | |
I run a 500mah 20c in my MRC with a Tekin B1R and a HH mini-TM and i get about 25min, IMO very respectable time for how hard i am with the throttle. | |
06-16-2011, 10:12 PM | #15 |
06-17-2011, 11:26 AM | #16 |
06-17-2011, 11:51 AM | #17 |
| We run 2S 325mah LiPO packs from CheapBatteryPacks, about enough to run 2 comp courses/pack. They are VERY small packs as well.
06-17-2011, 09:14 PM | #18 |
I'm probably going to squeeze the biggest battery in that I can. I'd like to get well over an hour of run time.
06-18-2011, 12:28 AM | #19 | |
A- Bigger battery is harder to fit in the small MRC B- Weight distribution won't be as good as using a small battery with more wheel weights C- It costs just as much to get several small batteries as it is to get 1 big battery D- You can be charging the small ones while your running another small one. With one big battery you would be limited to how long it will run, then you have to wait for it to charge (assuming you only have 1 big battery) I would suggest going 800mAh or smaller. The 800's are about the biggest that will fit easily into the MRC and even with just 2 of them you will get over 1.5 hrs of run time total. | |
06-18-2011, 03:10 PM | #20 | |
Will an 800 fit on the front axle? | |
