06-18-2011, 10:07 PM | #21 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
iif your looking for a good brushed motor setup is castle creations micro sidewinder ($60 and can run brushless), crawler mafia motor or reedy stump puller. my duaghter runs a novak mongoose and it works pretty well for what it is. |
06-19-2011, 05:49 AM | #22 |
Rock Stacker Join Date: Jun 2011 Location: Red stick
I as well went with mongoose. It just seems like it is proper choice for me. I couldn't find the system locally so I ordered it with mip shafts from rpp. I guess I should go for sets of tires now, rovers and chisels good. Is there another that is worthlookin at?
06-19-2011, 07:52 AM | #23 |
Rock Crawler Join Date: Oct 2010 Location: Reno
| Run your stock MRC pro tires before you buy tires. They work really well.
06-19-2011, 07:52 PM | #24 |
I planed on wearin stockers out and as there is no budget constraints and I see no reason not to have 2 or 3 sets available to choose from.
06-19-2011, 08:01 PM | #25 | |
Newbie Join Date: Dec 2010 Location: Hattiesburg, MS
Since this is my first leap into crawling I'm still unsure on how to go about weighting tires. I have a bunch of stick-on weight strips I use for my 1/10 short course trucks but I'm not sure how that will work. Do you put the weights inside of the rim (under the foam) or in the "well" of the rim? Or should I just buy some weighted rims? | |
06-19-2011, 09:59 PM | #26 |
I am going to get set of BWD Vertex rims.but for My stockers I wraped with lead in well with 45gr on all wheels and.on the front I plan to get sticky weights an stick to outside of floatin ring to get me around total 3-3.5 oz Damn i just seen your local is Hattiesburg I was just in lucdale with family. Last edited by Whop; 06-19-2011 at 10:02 PM. |
06-19-2011, 10:54 PM | #27 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
I stuck weights on the inside of the floating ring, on the inside of the wheel itself (next to the knuckle), and on the outside of the floating ring. I think its now about 5-6oz per front wheel now. |
06-28-2011, 12:50 PM | #28 |
Quarry Creeper Join Date: May 2011 Location: USA
Is there hesitation with getting the mongoose ESC? Meaning is it not as good as other choices out there?
06-28-2011, 02:29 PM | #29 |
I am very pleased with mongoose setup. I went with this setup cause I am not fan of excelerion. An I wanted brushless not brushed mantanice purposes this is not a comp rig so the "cogging issue".which I have Yet to experience wasn't a issue for me
07-01-2011, 07:01 PM | #30 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
I love my Mayhem servo from RC4WD. In fact I am going to be getting my 3rd for next MRC project for my 5yr old. Torque @ 6.0V: 220oz (16kg), Torque @ 4.8V: 206oz (15kg) Speed @ 6.0V: .16 sec, Speed @ 4.8V: .18 sec Weight: XX / XX oz "J" type connector with approx. 5" wire Standard size servo http://store.rc4wd.com/Mayhem-High-T...vo-_p_484.html |
07-10-2011, 09:38 PM | #31 |
| http://store.rc4wd.com/Mini-12mm-Whe...r-4_p_273.html Do yall no if these will work? I really just want em on front so tires get out of servo an batt |
07-11-2011, 09:11 AM | #32 |
| I have not purchased that one so I can not say but this one works. You may need to drill your wheel's center hub hole slightly larger. http://www.tcscrawlers.com/2.2-Wheel...2-p-16233.html |
07-11-2011, 07:39 PM | #33 |
They Well I will find out they were ordered by my brother. I got him hooked on rc rock crack I mean rc rockcrawling. I had a axle knuckle pin fall out so I have 3wd at moment is pita the wheel hex pin fits but either way I need a pin set |
