06-21-2011, 03:04 PM | #1 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
| Redemon's Slow Progress Pro Roller Build
Well I finally got my pro roller in the mail today. I dont have anything to put in it just yet. (couldnt pass up the deal) This will be a slow build im sure. I tried to see if my 1/16th VXL motor would fit, it wont it is just a tad to long. Im not gonna cut up the carbon chassis. Plans on what im gonna buy: Hitec HS-645MG A few lipo batteries Not sure on a motor yet, prolly gonna get a brood or a stock one for now Tekin B1R CC BEC Gonna use my traxxas link 2.4 radio for now The normal Losi aluminum stuff (knuckles, Carriers) And the Losi Outboard kit. Thats it for now I guess. This little truck is cool, I cant wait until I get to play with it. I have been collecting rocks for the past few weeks. Cell Phone Pics for now: Poser Crawling on my MREVO: Thanks you guys for answering all my ?'s before I bought this truck. Really like the way you guys run this site. |
06-23-2011, 10:50 AM | #2 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Did the 16th vxl motor fit on the motor plate of the tranny okay? I am building a scaler with one and using the SCX chassis so that's not an issue. I would like to use the vxl motor since it's water proof.
06-23-2011, 01:40 PM | #3 |
It looks like it will bolt up. But it doesnt have enough room to actually be flat on the plate. I will get a pic in a minute. I REALLY wanna put it on the truck. Would be one less thing I need to buy. Only other problem is there is no drag brake on the vxl system. |
06-23-2011, 02:12 PM | #4 |
Alright I wanna put some weights on the wheels. I tried to read around to figure out where they go. I cant find anything. Do you put them on the inside of the tire or the inside of the wheel? And know that I read that it sounds confusing. It seems the wheel weights I have at work would be to thick and rub the knuckles or hexes. If they go inside do you put them directly on the wheel or on that ring? |
06-23-2011, 03:24 PM | #5 |
Put them on the wheel but on the inside underneath the foam, so inside the tire.
06-23-2011, 03:45 PM | #6 |
Ok good. Im doing that tomm. |
07-02-2011, 03:11 PM | #7 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
Did you ever get that VXL motor to fit. I just ordered one and would like to use the extra 1/16th VXL system I have for it.
07-05-2011, 07:34 AM | #8 |
It will not fit without doing some cutting on the chassis. Im just not cutting up this brand new truck just yet. |
07-23-2011, 06:17 PM | #9 |
Well I finally got the body painted and some new pics taken on my rock pile that im building. Im ordering my steering servo and some lipos tonight. |
07-28-2011, 06:29 AM | #10 |
Well I have gotten a few things done to the truck I put wheel weights in the wheels. Made some holders on the upper links Ordered my Steering servo. I got a great deal on a mongoose 18.5 system and a 2.4rx. Just need to order me some batteries and I will be set. Hopefully most everything will be here today or tomm. |
07-29-2011, 06:05 AM | #11 |
Got my HD servo in and installed it in the center instead of off to the side. Why in the hell did losi design this thing so a 1/10th scale servo can fit but wont bolt up. Crazy to me. Anyway, I wound up having to use my old steering arm that came off my Erevo. Worked I think. We will see tonight. (motor gets here today) Pretty good turning radius I believe. |
07-29-2011, 08:47 AM | #12 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
My full size 5645 servo bolted right on and I used the longer drag link provided in the box. You will love the speed and power the mongoose. The drag brake is weak, but still very capable.
07-29-2011, 09:11 AM | #13 |
Well this isnt a Hitec so that might be why it didnt bolt up. I might make something, or see if this will hold up. |
07-29-2011, 09:34 AM | #14 |
Rock Crawler Join Date: Nov 2010 Location: Springfield, Oregon
That is a tight turning radius! I should have mounted the servo in the center like that. Mine always hit the left wheel at full lock. Good job!
07-29-2011, 09:38 AM | #15 |
Yeah I saw that at first and I hated that. So i just moved it over a little. |
07-29-2011, 10:04 AM | #16 |
What batteries are you running with the mongoose system? What gearing?
07-29-2011, 11:39 AM | #17 |
I ordered my 2s lipos last night from value hobby. (they have deans plugs on them already) And they are a 800mah/30C. Cost me 12 dollars. They also have flate rate 3.99 shipping Im going to run stock gearing for now. Might change it later not really sure. |
08-03-2011, 07:44 AM | #18 |
Got my batteries in. Did a run and broke the steering arm the goes on the servo. HAHA. I really want aluminum arm and the links to be aluminum also. Gonna have to either make it or find someone that makes it. But that servo is a bad boy. I like the truck also, very fun to drive. The novak system is strong. |
08-03-2011, 08:03 AM | #19 |
Quarry Creeper Join Date: Jul 2011 Location: Hemet
hey...you might want to use all the holes to bolt on the servo...i did the same thing you did, and ripped off the side pieces from rolling
08-03-2011, 09:50 AM | #20 |
Im going to make something so I can use all the spots
