06-27-2011, 06:22 PM | #1 |
Newbie Join Date: Jul 2008 Location: Orange County
| LF Tire rubbing steering Servo
I just got my MRC Pro running and I ran into a problem. Whenever I make a right turn the left front tire rubs against the steering servo. I had to dial my steering EPA down to 60% of the travel which completely negates any advantage of the zero ackerman steering setup. Actually it is kind of hard to manuver with that little steering. A MRC Pro with a 1/10th scale servo (Mine is an ACE 1313) cannot be an unusual set up, does anyone have a fix for this? Everything else is completely stock: tires, axles, steering knuckles etc. |
06-27-2011, 06:25 PM | #2 |
Yep, it rubs. The mini servo fits better but also rubs. I made a mount to center the servo and mount the battery behind it on the uppers. Now the tire hits the springs at full lock. |
06-27-2011, 06:48 PM | #3 |
| +1, using a 1/10th scale (AKA full size) servo means it either hits the LF tire @ full lock right, or, you make a plate to center the servo on the axle. This happens even with the stock knuckles. |
06-27-2011, 07:03 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
man, i just got finished wiring mine up and noticed the same thing. does anyone make an aftermarket centered servo mount? i can fab one if needed. but if they are out there and fairly cheap, it will save me some time.
06-27-2011, 07:13 PM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
rcbros has a nice 4 link servo mount
06-27-2011, 08:39 PM | #6 |
06-27-2011, 09:17 PM | #7 |
sorry I just checked also and can't find it. I just bought mine in april so not sure what happened
06-27-2011, 10:31 PM | #8 | |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
BilletWorks. Don's mount works great and allows for ota steering as well. | |
06-28-2011, 04:54 AM | #9 | |
cool. I shall look into bwd. Thanks. | |
06-28-2011, 08:57 AM | #10 | |
It seems that many manufacturers are no longer supporting the MRC. Every time I do a search for a part there is more than a 50/50 chance it has been discontinued. | |
06-28-2011, 09:48 AM | #11 |
That is why I made my own using a CKRC servo plate. All you need are the upper link attachment points.
06-28-2011, 04:22 PM | #12 |
rcbro front mrc 4 link mount is back in stock just got pm from him and i checked the site
06-29-2011, 12:05 AM | #13 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
| is this mount from RCbros a direct drop in for the MRC pro and it's 4 link? I'll grab one if it drops right in and lets me center up my HS5645 without having to mess with anything else.
06-29-2011, 12:21 AM | #14 |
| I believe it is. I think my son is running one (he's sleeping, can't ask right now.)
06-29-2011, 07:24 AM | #15 |
you have to get the 4 link one from rcbros but you will have to get or make new arm to the knuckle because your centering the servo so the length is changing
06-29-2011, 08:44 AM | #16 |
Thanks for that, I just ordered the 4 link servo mount and the servo posts. It is amazing to me they would design such a flawed system and try and pass it off as a "Professional Roller". In the stock form it is not really usable. I cannot think of any competition where you can have a chance at winning if you only have 60% of your steering!!! I guess that is why they are selling them off at $65!! |
06-29-2011, 08:45 AM | #17 |
| When I centered my servo I just flipped the servo so the output shaft is closer to the left wheel and was able to use the same link.
06-29-2011, 12:07 PM | #18 |
