Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Got my HB Rovers now need advice on which foams to run
Old 06-28-2011, 06:32 PM   #1
Default Got my HB Rovers now need advice on which foams to run
Hi all.
Finally got my pl titus and HB rovers red dot in. Was wondering which foam should I install. Should I use the ones that came with the rovers or the blue ones from the mrc pro roller wheels
Thanks
generem is offline   Reply With Quote
Old 06-28-2011, 06:58 PM   #2
here ya go. best foams ever.
softs up front firms in the rear
http://www.crawlerinnovations.com/in...mart&Itemid=63
CrawlHer is offline   Reply With Quote
Old 06-28-2011, 07:02 PM   #3
I like the C.I. soft up front and med. in the rear.
Jslick is offline   Reply With Quote
Old 06-28-2011, 07:15 PM   #4
Just ordered sets of soft and mediums.
Thanks
Old 06-28-2011, 08:18 PM   #5
Also eddie at CI will usually hear you out on what you run. How you run and where you run and help you create a foam that is right for you. He is that kindof class act.
RickM is offline   Reply With Quote
Old 06-28-2011, 08:25 PM   #6
CORRECTION
i meant mediums in the rear. thats what i have not firms.
Old 06-28-2011, 10:41 PM   #7
I'm kinda new at this so not really sure what I need for the moment. I'm basically relying on this forum for advice. Hell.... I'm not even sure where I can find a crawl spot in my area. Lol
But I was going thru the ci site and I'm kicking myself in the @$$ right about now. I could have save some $$$ if I would have orders my tires and foam from him. Oh well... From now on, I'll check the vendors b4 buying from somewhere else
Old 06-28-2011, 10:50 PM   #8
Thanks
Nice combo. I like the memory foams too... you should try those out when you get a chance
helhedded is offline   Reply With Quote
Old 06-29-2011, 01:22 PM   #9
5th D Owner/Driver
cboggs's Avatar
Try the stock foams.
cboggs is offline   Reply With Quote
Old 06-29-2011, 02:08 PM   #10
Stock that came th the rovers? Or the blue losi ones
Old 06-29-2011, 02:49 PM   #11
5th D Owner/Driver
cboggs's Avatar
Stock Rover foams.
Old 06-29-2011, 03:12 PM   #12
Stock Rover foams.
My rovers came new with no stock foams
CI rover\foam combo
DickyT is offline   Reply With Quote
Old 06-29-2011, 03:52 PM   #13
Memory foams are good when its hot out. CI foams do work very well. CBoggs, our 2010/2011 1.9 champ suggested stock foam and I agree. The CI soft foams are too soft for my rig.
TedBull is offline   Reply With Quote
Old 06-29-2011, 05:29 PM   #14
Tts worth trying different one to see what works for you. I like my stock foams, they were free
Smiles is offline   Reply With Quote
Old 06-30-2011, 12:15 AM   #15
Right now I have losi blue foam in front and rover stock foam in rear. Just been climbing the couch and its night and day from stock tires. 4oz in front 0oz in rear. Will be trying different combos when the CI's come in but while doing searches... There were so many positive post about them that I just had to try em. They were inexpensive so well see. I am noticing that there is alot of the side giving out with the stock losi foams so im hoping that the CI soft will be better
Old 06-30-2011, 06:02 AM   #16
I put Losi memory foam in my rovers, and talk about soft! not sure if I'll like it that soft or not....
sickpuppy1 is offline   Reply With Quote
Old 06-30-2011, 11:39 AM   #17
Thats why I ordered the CI's
