07-10-2011, 12:16 AM | #1 |
Newbie Join Date: Jul 2011 Location: Seattle
| Homemade BEC?
I was searching on forum to get some info about BECs and I figured out the basic roll of BEC is to regulate voltage goes into servo to 6V and prevents sudden voltage change to the entire circuit. Then, shouldn't it be possible to make my own one? With my 7.4V lipo, the ration of the voltage regulating should be output voltage (6V) / input voltage (7.4V) = 0.8108 ==> 0.8 approx. And I looked on Tekin website to find out capacitance for caps and they suggest 16V 180uF capaciror for b1r ESC that I just ordered. I have 2 of 25v 1000uF cap so it should be more than enough. What I'm thinking is to build a BEC system with my own components. Guess it would be much cheaper if I success with this one lol. How do you guys think? Any tips would be help! Thanks. |
07-10-2011, 07:32 AM | #2 |
Ummm...it's a bit more to it than that. You are thinking like a resistor, "I have X voltage & I want it dropped to Y voltage". What you really want is, "I put in a range of voltages, but always get out a single voltage". Having it adjustable is nice as well, unless you want to build a BEC for each output voltage you want. Not saying you can't/shouldn't do it, just saying it takes some more. |
07-10-2011, 09:58 AM | #3 |
Electronics section?
07-10-2011, 10:56 AM | #4 |
Just wire the lipo straight to your servo. |
07-11-2011, 10:11 PM | #5 |
Thanks for response guys. I think I was confused voltage regulator with voltage divider when I was writing my post. I though I could make voltage regulator on my own since I have made one in my class before. Anyway, comment from you guys helped me a lot to understand what I need to do and I will try to build my own BEC later. |
07-17-2011, 10:02 AM | #6 |
Pebble Pounder Join Date: Feb 2008 Location: here
| http://www.dream-models.com/eco/electrics-bec1.html Haven't tried it myself but looks promising. An easier route is to buy a 10A BEC from Castle for around $20. |
07-17-2011, 10:07 AM | #7 | |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
or a resistor and an old servo wire for $2 I was just thinking of this the other day! I havent did the math (google) to find out what resistor i needed, but I was also thinking of trying it. set it at a good 5 or 6v BEC wired to the RX from the battery. | |
07-17-2011, 10:08 AM | #8 | |
07-18-2011, 12:10 PM | #9 | |
As I stated before, a resistor drops the voltage a certain amount, but this also means your voltage to the servo will vary as the pack voltagfe varies. This is why we run BEC's NOT resistors. | |
07-18-2011, 12:51 PM | #10 |
07-18-2011, 06:45 PM | #11 | |
Before you flame just remember we are only trying to help out. I wash my hands of this. Good luck with your electronics experiments. | |
